MS Publisher 2007 & Odd looking text
Posted by nonnie_ga (My Page) on
Wed, Oct 24, 07 at 17:08
I have recently started using MS Publisher 2007 and like it. I am doing a newsletter and simply cannot put the footer in it correctly. I do it step-by-step as the instructions say and it doesn't come out right. It will let me put the footer in and the page number but it repeats the same page number on all of the page.
With the text problems, I was pushing buttons while checking outmy newsletter and now I have dots(...)between each words and, every now and then, I get a backward P.
What ve I done and what can I do to fix the first and get rid of the dots?
RE: MS Publisher 2007 & Odd looking text
Nonnie, I don't have MS Publisher, but I do have MS Word, and I think I can explain about the dots and backward P.
Look on the tool bar at the top of the screen. Do you see an icon for a backward P? If so, just click on it (once), and the dots and P's should disappear. Click again, and you'll see them (it's a toggle). The dots show you how many spaces are between the words (if there are two dots together, that means you've got a double space between the words; this helps you find it more easily). The backward P's indicate the return at the end of a paragraph (you should see another one at the left margin if you've skipped a line between paragraphs). It's a useful little gadget! It doesn't change anything except the view on the screen.
As for the footer problem, here's how to fix it in Word (not sure if it's the same in Publisher, but worth a try): on the toolbar, click on View and then Header and Footer. Then click on Page Setup (the icon shows an open book). For Section Start, choose "Continuous." I think that will give you continuous page numbering. On that screen, you can also select other choices for the way you want headers and footers to appear.
I'm a little rusty on this; hope my advice is correct.
Sue
