Word/Excel Files Open in Viewer Mode - MS Office Std Edition 2003
Posted by daltex (My Page) on
Sun, Oct 2, 11 at 12:14
When I receive a file (both xls and doc) created by someone else or open a file stored on my system, it initially opens in "viewer" mode only, whereby I can't edit/save the file. I DO KNOW I can go to file/open for editting and a new copy will open that I can edit. Somehow a setting has changed (after someone worked on my PC), since I previously could open up a file and edit/save immediately.
I have tried searching tools/options and any other area, but I must be overlooking where I need to make the change ... Can anyone provide some guideance?
RE: Word/Excel Files Open in Viewer Mode - MS Office Std Edition
Use Windows Explorer. Right-click the filename, then select Properties. Is the file marked as "read-only"? If yes, uncheck it...click APPLY, then OK. Did that make a difference?
I followed your suggestion on a file saved to my system and the file did not have the "read only" box checked, but when I open it ... it defaults to "file viewer" mode.
When I try the same action on a file sent to me, selection of properties does not show the check boxes for read only, etc.
When you open the file, look at the yellow band near the top of the screen. Locate a boxed phrase saying "Enable editing" toward the right. Click it.
RE: Word/Excel Files Open in Viewer Mode -- MS Office Std Edition
I truly appreciate azinoh and you trying to help. I do not see the yellow band, nor the "enable editing", so are you sure your version is Office Std 2003 and not a "newer" version?
A stretch here, but did you check the file associations?
DA
