| I actually have some work I put on several CD's a year ago but now have found that none of the public library computers I use take anything other than a flash drive. How would I save my work off these old disks and put them on to a flash drive? |
| It is a simple operation really assuming you have the flash drive/s. Right click the Start button |
| To be on the safe side remember to use the Remove Hardware Safely utility in the Notification Area before removing the drive. Failure to do so is not a 100% certain of failure. However, the possibility is there. The most common failures are loss of data, data that becomes read-only, and previously used data space that can no longer be utilized. DA |
