Mon, Sep 26, 11 at 20:54
| I have several websites that autofill the info boxes once I type the first few letters, but some of them have several options that are no longer used because I changed the name or password. How do I edit that list with Windows XP and IE?
Thanks! |
| The link below explains how to do this in IE7 and IE8. See if that helps. There is a shortcut to Internet Options also: Click on Tools > Internet Options > then follow the instructions from Step 2 on in the link below. |
Here is a link that might be useful: Delete AutoComplete saved information
| My IE9/vista.. if I change a stored/existing autofill data field on a webpage.. as soon as I start typing the value I think.. it gives a drop down box to select the value from. Put your mouse over that value\ you want deleted.. push the keyboard delete key. Type in the new value & when submitted, IE should save it. |
- Posted by michelle_phxaz (My Page) on Tue, Sep 27, 11 at 3:17
| bbbluz, I had found that, but it deletes everything, not selected usernames. Mikie, I never though of trying to delete them from the page, but it worked just fine. Thank you to you both for your responses! |
