Printer problem
Posted by john_ny (My Page) on
Sun, Aug 12, 12 at 16:12
HP Photo Smart P 1000 Printer Windows XP
I get a little yellow triangle with an exclamation mark in it. When I click on it, I get a message that my printer is not connected. I checked both ends of the USB cable, and they are connected. I checked the power cord, and it's connected, and the on light is lit.
Any ideas? Thanks.
RE: Printer problem
Hi john_ny
Disconnect the USB connection at the computer for the printer, reboot/ restart the computer, now reconnect the usb for printer See what that does.
Joe :)
RE: Printer problem
Thanks, Joe! Will try it.
RE: Printer problem
Don't forget to wiggle the cables too, in an attempt to see if it's a bad cable, I have to wiggle my cable all the time, need to get another one.
RE: Printer problem
Thanks again, Joe. What you told me to do didn't work. I got a message that the computer could not find the new USB device. The thing about the cables was to be my next question. Could it be just a bad cable? My second question was, Might I have to re-install and, then, would I have to uninstall the current first? I'll try another cable in the morning, but it could also be that the thing is just worn out. Although it doesn't get heavy duty use, it's just a little shy of 13 years old.
RE: Printer problem
I'd ditch it being 13 years old. If you do get running, in the end you still have a 13 year old printer that will be subject to failure.
Joe
New printer for you!
Here's a few good printers here, I like the IBM a good deal at only $30,800
Here is a link that might be useful: -most-expensive-printers/
RE: Printer problem
Again, thank you Joe. This thing has worked perfectly until 2 days ago, but maybge it's time to say goodbye. My 17 year old cat was not too happy to hear this diagnosis.
RE: Printer problem
You're welcome, if you have the disk I guess you could try re-installing, see link
Here is a link that might be useful: hp printer
RE: Printer problem
Thanks; it was just the cable, I put another one on and it worked like a charm. The only thing was that it printed everything that my wife and I had been trying to print when it wasn't working; about 30 pages!
