Error on web page
Posted by stitcheasy2003 (My Page) on
Mon, Aug 15, 11 at 10:44
When I open my web page I get an error that says
"500 Internal Server Error", then a line under that, under the line is says "nginx". I cannot get anything. I have even deleted firefox. How do I correct this? Thank you
RE: Error on web page
nginx maybe is installed by software from your ISP or Email client. It very well be your normal method to connect to the web or email account. Or could be some browser add-on. Its often proxy/advertising server. Run SuperAntiSpyware.com full scan might be a good idea.
Your 500 error ... the server is aware that it has encountered an error or is otherwise incapable of performing the request, but doesnt know what went wrong.
YOu say you deleted Firefox..
Do you mean you UnInstalled it ? If you truly simply just deleted it you will need to reistall same version & then use the uninstaller..
Nginx
that is what Nginx is.
what version of windows are you using and are you getting the error in all browsers?
Not understanding at all why you would delete or remove firefox??? If that leaves you with only one browser you need to add either firefox back or Opera or Chrome you really do not want to only have IE in case it should have a problem.
Do you happen to have anything HULU related on your pc?
here are the links to the scans you should run
SUPERAntiSpyware Free Edition
be sure to update the program then do a full scan
Malwarebytes' Anti-Malware (Win) - Detecting and Removing Malware
be sure to update the program and do a full scan
run those just to make sure you have a clean machine and it is not malware causing your problems.
