| I had to move my computer to the upstairs, so I got a net gear wireless adapter for it. It works fine but everytime I turn it off in rhe hibernate position, it shuts down completly and I get this error message after I have to re boot it
Problem signature:
Additional information about the problem:
Files that help describe the problem:
Read our privacy statement online:
If the online privacy statement is not available, please read our privacy statement offline:
Am I doing something wrong, is there a way to avoid it shutting down completly?
| ' I got a net gear wireless adapter ' Open device manager.... Look for an updated driver.. hopefully with WHQL, Windows Hardware Quality Labs approval. |
- Posted by christophern (My Page) on Mon, Aug 13, 12 at 6:08
| Thanks, it says it is the latest up dated driver. |
| Actually, I would suggest to ditch the hibernation and sleep options and shut it down normally...always seems to be problems associated with those two functions |
| '... everytime I turn it off in rhe hibernate position, it shuts down completely...' Not sure you can turn it off when in the hibernate position. Can you explain what you were doing? is there a way to avoid it shutting down completely? I have never ever used the hibernate feature on computers. |
- Posted by ravencajun (My Page) on Mon, Aug 13, 12 at 13:48
| I agree I never use hibernate I disable it on everything has tended to cause more problems than it is worth. Mine are always up always ready. I just set all the power options to always on. |
- Posted by christophern (My Page) on Mon, Aug 13, 12 at 16:27
| Well, I have always used the hibernate function as it shuts down the machine completly but just comes back to where I shut it down, it does not have to re boot. Now it does. I just don't get why.I suppose when I move it back to the ethernet cable it will return to normal, hopefully. |
| Might go back to Device Manager and look at Properties for the wifi network adapter. It will have list of options that you can change settings for... maybe something there will stick out. It also has a Power Management tab.. probably should make sure to allow power management to kill it when it hibernates or sleeps. Win7.. hibernate & sleep modes should work, if settings all set ok and whql drivers. |
| Maybe look in your wired network adapter too.. with it not in use,, maybe its the culprit. |
| Hi christophern, Out of curiosity could you post this, Download WhoCrashed See link below for whocrashed. Click on the file you just downloaded and run it. 1 Put a tick in Accept then click on Next. 2 Put a tick in the Don't create a start menu folder then click Next 3 Put a tick in Create a Desktop Icon. then click on Install and make sure there is a tick in Launch Whocrashed before clicking Finish. WhoCrashed will create report but you have to scroll down to see it. Thanks Joe..:) |
Here is a link that might be useful: WhoCrashed
- Posted by christophern (My Page) on Tue, Aug 14, 12 at 5:49
| Maybe look in your wired network adapter too.. with it not in use,, maybe its the culprit. That was it! Thanks |
