| I'm having an issue lately, would like a good on line scan
done to remove any bugs I may have picked up, Thanks in advance!!! |
- Posted by ravencajun (My Page) on Sat, Aug 18, 12 at 12:01
| Try ESET�s Free Online Scanner and of course use an updated malwarebytes free scan superantispyware |
| Hi rockcut1, I like Eset online scan, You will need to use Internet Explorer to use the scan, I would suggest that you run Malwarebytes, SuperAntispyware, first and let those programs remove anything found. Can you describe the issue you're having with the machine? You need to be also somewhat careful with on-line scans as they can produce false positives more often then say Malwarebytes. You can run the scan and choose the option not to remove threats and post the log here for further review if you would like. "Online Scanner is not intended to be used as permanent replacement for your computer's security. It's designed to only detect and remove threats via on demand scan." Joe
Here is a link that might be useful: Eset on line scan
| What AV do you currently have on your machine... |
