Can I defrag a scan disk?
Posted by minnie_tx (My Page) on
Sun, Jul 3, 11 at 0:56
I have a little Scandisk cruzer mini 1.0 GB
I use it to transfer MP3 files created on one computer to a different computer. After trnsfering I also delete the files on it and reuse it.
Tonight I transferred 2 files and followed the routine then checked the properties on the disk and it read 931MB used and 45MB free space
The pie chart shows just a tiny sliver of free space. Is ther a lot of hidden stuff I need to get off of it?
TIA
I read someplace you shouldn't defrag these things
RE: Can I defrag a scan disk?
I have defraged flash drives occasionally. One hidden/plugged in drive in my laptop is an express card drive bought on sale for low bucks which turned out in fact really to be nothing more than just a usb flash drive in the express card form - it is constantly defragged by my automatic Perfect Disk program.
I was wrong I have a San)disk that I use not a ScanDisk
RE: Can I defrag
I tried o defrag it but it said not enough room to do it and remove files. There are no files showing on the disk weird
Might go to folder options in control panel, choose the view tab.. unhide 3 or 4 things there. Varied by computer... mine= the picture below.
Here is a link that might be useful: http://prntscr.com/27gxu
If Mikie's method above does not give you the fix you could always reformat the thumb drive. To do so
click start
click My computer
right click on the thumb drive
click Format in the pop up window
select Fat32 or NTFS
MAKE SURE you have selected the right drive because everything gets erased!!!
Wow That was fast thanks !!
? someone said to hit eject when removing drives do I hve to? or just pull it out? TIA
DO NOT pull it out Minnie.
If you have XP there is a small icon near the clock with a left facing arrow on it. Hover over and the info will appear. Click this then click the pop up to remove, wait till it says it is good to remove
Windows 7. Right click on Start
right click on the thumb drive on the left side of your screen
in the pop up click to eject.
I have xp If I right click on the drive numbe there is place to hit eject which I do but no notice about ok It will jump down to a lower drive and my control panel shows up so then I take it out figuring that is the thing to do
Minnie,
Obviously if you are using a thumb drive the data on it is important to you. To not remove the drive "safely" places this data in harms way. The most common drive failures caused by unsafe removal are loss of data, data converted to read only, and loss of space on drive.
DA
Thanks everyone for your help right now I'm using the thumb drive for transferring into from one to the other .
Happy 4th !!!
