Sat, May 5, 12 at 16:01
| One minute we had wireless, the next it was gone. The wired desktop is fine, but the laptop and netbook cannot find the wireless connection. We've turned everything off, unplugged, rebooted. Still, no wireless connection. Any ideas? |
- Posted by ravencajun (My Page) on Sat, May 5, 12 at 21:53
| did you unplug your router and modem both if not shut down the computers, unplug the router and modem, then wait about 5 mins, then power up in this order, modem first let it get lit up, then power up router let it get lit up then power up computers. The order and time are very important. If that does not work look at your router and see if the signal lights are all on that should be on. |
| If you are in an area where other wireless networks are active, it's possible that one or more of them are strong enough to interfere with your ability to connect to your own network, especially if you are using the same channel. I use a program called inSSIDer and find it very useful to see whats going on. There are as many as 12 networks operating in my area and they are constantly switching channels it seems. With inSSIDer, I can see which channels they're using and adjust my channel if needed. It's free and has helped me on more than one occasion. |
Here is a link that might be useful: inSSIDer
| Thanks so much for your responses. Long story short, apparently AT&T had an "issue." We found out several neighbors had the same problem. They are coming to the house Wednesday to "fix" the problem. Thanks again! |
