Mon, May 7, 12 at 13:15
| Just that. Need help |
| The problem is probably not with Outlook Express but with your e-mail server. Do you use a web based program such at Hotmail or Gmail, or do you use a service provided by your ISP? Definitely need more information here before any help can be rendered. |
| Yes! And there should be some sort of error code generated is there? |
| Don't know about Outlook Express, since mine is Outlook. In Outlook, if accidently set it 'work offline', it won't send mails out. The 'work offline' option is under 'FILE'. |
| I had multiple phone/comp. problems untill the man replaced the line TO THE HOUSE. Lost OE completely and was irked! I kept restoring system and it came back WITH O.E. Of course , you have to do SOME updating SOMETIMES after a restore. That was the only fix this old man knew to do and wasn't sure that it would cure my ills, but it did. I've used O.E. for so long that I just hate to TRY and go to another e mail program. |
- Posted by mike_kaiser (My Page) on Wed, May 9, 12 at 13:52
| Your phone or cable line being replaced has nothing to do with Outlook Express. I would suspect that if you've done multiple restores a setting got changed somewhere. What happens when you try to send an email? Do you get any kind of error messages? |
