web dynpro
Posted by katy1234 (My Page) on
Thu, Apr 14, 11 at 17:33
I'm trying to access a site that says "my browser does not support Web Dynpro. I have the latest versions of both IE and FireFox and I've update Adobe Reader but nothing helps. I don't know what to try next. This is the first time in thirteen years of being on the internet that I've seen this Web Dynpro message. Any help would be greatly appreciated.
RE: web dynpro
I forgot to say that I have Vista Home Premium if that makes a difference.
RE: web dynpro
it is due to sloppy coding on that site is my guess and not updating the site or products for the newer versions of the browsers. Seems that web dynpro is causing that problem a lot if you google it.
I found this: On IE8 have you tried using the compatibility button next to refresh?
The Compatibility View button
RE: web dynpro
Raven,I'm using IE9 but I tried your info out and it WORKED! OMGosh,I was pulling my hair out trying to figure out what I needed to do. I can't thank you enough. I've learned a lot reading this forum and am so glad I came here with my problem. :) Thanks again!
RE: web dynpro
good glad you worked it out yes it should be the same on Ie 9 too.
