| IPhone is the only 'Apple' I use and use the camera often. Many times when I post a photo it is upside down. I have used Microsoft Picture Manager to rotate it properly, but when I post the photo it shows upside down. On the Apple forum they blame Microsoft for not reading some tag. Whatever.....does anyone else run into this? I miss my Blackberry. Thanks as always, |
| If your posted photos are always upside down, I have a guaranteed solution. The next time you're about to snap a photo that you'll want to post: 1) Prepare to take the photo and hold your phone the way you normally do 2) Pause for a moment and rotate the camera 180 degrees 3) Take the photo. You'll find when you post it, it's not upside down. |
| Hi Jane, Is there anything here that helps... Joe |
Here is a link that might be useful: does-my-iphone-take-upside-down-photos
| Thanks for the links Zep. I did check those and that's where they talk about tags which Windows doesn't read. The recommendation is to use Picassa which I don't know how to use to post photos here. Snidely, I have tried that many times. It doesn't work. It seems the way the picture comes into the computer is 'willy-nilly.' Sometimes its correct, other times its sideways or upside-down. Even when I correct using MS Photo Editor, it doesn't correct the problem. The photo looks right on Photo Editior, but when I bring it into GW, it rotates again. Very weird, I've never had this happen before. I'll have to learn Picassa. Jane |
| Just wanted to say thanks for the info given. The only fix I could find was to use Picasa. I load the photos and they are automatically straightened. Then I 'save' to My Pic Folder and they are correct. Its a pain, but I agree, Apple needs to fix this. Jane |
