Zone Alarm is Blocking Spywareblaster
Posted by juneroses (My Page) on
Sat, Mar 3, 12 at 17:35
Background: Win XP with SP3; Avast, MAM, SAS, Spywareblaster, Spybot S&D, Zone Alarm; Cisco router
I'll apologize first. If I'd known I would have problems and need your help, I would have kept precise records.
Yesterday, I bit the bullet and decided to accept the Mozilla update. I think Spywareblaster may have also had an update. Anyway, I did the updates and all seemed well. Methodically did the updates for the other security programs I had (listed above). All programs updated and are working except for Spywareblaster; Zone Alarm is blocking it from connecting to the internet (port 12080). I found this via the ZA log. What I can't find (or don't recognize if I have come upon it) is how to change this so ZA does allow Spywareblaster.
I attempted to solve the problem by removing Spywareblaster with Revo Uninstaller. I then downloaded and did a new install of Spywareblaster. This maneuver didn't fool Zone Alarm, however - it still refuses to let Spywareblaster connect to the internet.
Any suggestions? Or, maybe, I have enough security without Spywareblaster and should just delete it and save myself further grief?
RE: Zone Alarm is Blocking Spywareblaster
I use Firefox 11.0 and Zonealarm (free). I downloaded and installed Spywareblaster to see if my setup would block it. After installation, I ran Spyblaster to get updates. ZA asked if ok or deny -- I said ok, and got the updates. Is that different than your experience?
It's been a thousand years since I used ZA.
Have you tried right-clicking on the icon in your System Tray to access the available tabs and options. Back in the deep recesses of my memory I seem to recall access to a roster of installed applications, and the ability to change allow and deny; green check marks and red Xs.
DA
Sounds like spywareblaster was blocked once.. thats right, they had allow / deny settings for every program in a quasi complicated dangerious misleading wording.
If you have vista or win7 .. or win8
you dont need Zonealarms
No idea how to fix your problem but you have WAY too many security programs.
As long as Avast and ZA are the only two applications in real-time I see no problem with what you have. As always, a tiered approach to protection and detection is the proper action.
ZA
Ta-da!!! I fixed it.
For the 31st time (!) I opened ZA and looked through the various screens. I found "Appplication Control" and for Spywareblaster there were red "X's" under "inbound" and "outbound". In this same table SAS (which is updating) had green checks.
There was no indication that I could/should click on the "X's" but I thought to do so; a menu appeared which allowed me to change the red "X's" to green checks.
After this, when I tried to update Spywareblaster, it worked.
Thank you all for considering my problem.
Mike_kaiser, you're probably correct, and I'm heavy on the security programs. This computer is about 7 years old and over the years, I've slowly added these programs (and very recently, the router) as they've been recommended here. When one has been recommended I don't recall a corresponding recommendation to get rid of "x". So the list has grown.
My computer seems to be running fine and isn't particularly slow so I haven't inquired about what I could remove.
Personally, I think you are fine with your security programs. It's not as if you have a bunch all "running" at the same time. Glad you found the answer to your problem. Good work!
