| When I first start up it is fine, but after a few hours it slows down to the point I can't make it to the shut-down mode.
When I do shut it down and restart it works fine, but this is getting annoying! It is a Dell Latitude D5 with XP and Firefox running. Any ideas? |
| What is the make and model of the mouse itself? |
| Sorry Owbist, I should have been more clear. This is a laptop so I move the cursor with my finger. Would it be better to buy a wired mouse? |
| I just went and found an old corded mouse and it works great. Still, If you have an answer I would love to hear it! Thanks! |
| Just curious, are you using this laptop on your lap or a desk..if on your lap or another soft surface, you could be causing heat issues because you may be blocking the fan vents on the bottom/sides..What you are refering to is called the touchpad, not a mouse... |
| I am going to go out on a limb here and believe we are talking about the screen pointer. That is called a cursor. I like Gene's heat thought. Also, quite often a slow responding "mouse" is a result of lack of system resources. It could be the same here with your laptop's "cursor". In both cases as multi-tasking activities amass perhaps the system can't keep up. A reboot then creates a reset and everything starts over fresh. You might want to take a look in the startup as to what is running, DA |
- Posted by ThomasAnderson (My Page) on Thu, Mar 22, 12 at 8:42
| Download the touch-pad driver from the dell site and install it or install it from the driver CD you got. If already installed than select repair at the time of re-installation. |
