Opinions on ceiling height, beams, coffer please
katmu
9 years ago
CEILINGSDesign Details: Cuckoo for Coffered Ceilings
Classic, Structural-Looking Ceiling Panels Set a Room Apart
Full StoryDECORATING GUIDESPlease Touch: Texture Makes Rooms Spring to Life
Great design stimulates all the senses, including touch. Check out these great uses of texture, then let your fingers do the walking
Full StoryARCHITECTURECeiling Treatments Worth a Look
Add beams, boards and other embellishments to that blank expanse for a room that looks dressed from head to toe
Full StoryCEILINGSCeilings That Work: Designs for the Space Above
Coffer or vault your ceiling and give your whole space a lift
Full StoryREMODELING GUIDESCrown Molding: Is It Right for Your Home?
See how to find the right trim for the height of your ceilings and style of your room
Full StoryDECORATING GUIDES11 Tricks to Make a Ceiling Look Higher
More visual height is no stretch when you pick the right furniture, paint and lighting
Full StoryARCHITECTURELearn the Language of Trusses in Design
If figuring out all those intersecting beam configurations under roofs makes your eyes cross, here's help
Full StoryREMODELING GUIDESSupporting Act: Exposed Wood Trusses in Design
What's under a pitched roof? Beautiful beams, triangular shapes and rhythm of form
Full StoryMOST POPULARHeads-Up Hues: 10 Bold Ceiling Colors
Visually raise or lower a ceiling, or just add an eyeful of interest, with paint from splashy to soothing
Aims
mushcreek
Martinsville Architects & Building Designers · Suamico Design-Build Firms · Converse Home Builders · Katy Home Builders · Cibolo General Contractors · Hainesport General Contractors · Bowling Green General Contractors · Del Aire General Contractors · Evans General Contractors · Great Falls General Contractors · Klahanie General Contractors · New Bern General Contractors · Oneida General Contractors · Panama City General Contractors · West Lafayette General ContractorsAnnie Deighnaugh
Michelle
rmverb
