Drywall installed....what do I need to check?
stuarbc
Featured Answer
Sort by:Oldest
Comments (6)
jeding
10 years agostuarbc
Bull Run Architects & Building Designers · Plainville Architects & Building Designers · Ammon Home Builders · Garland Home Builders · Sarasota Home Builders · South Hill Home Builders · Takoma Park Home Builders · Cedar Hill General Contractors · Clarksville General Contractors · Jeffersonville General Contractors · Livermore General Contractors · Mount Laurel General Contractors · Seguin General Contractors · Waterville General Contractors · Woodland General Contractorsstuarbc
10 years agojeding
10 years agofirstmmo
REMODELING GUIDESFinish Your Remodel Right: 10 Tasks to Check Off
Nail down these key details to ensure that everything works properly and you’re all set for the future
Full StoryREMODELING GUIDESCheck Out Our Sweepstakes Winners' 2-Room Makeover
The laundry room's organization needed ironing out. The guest bath didn't make a splash. See the makeovers a Kentucky couple won
Full StoryUnlock the Secret to Keeping Keys in Check
Say goodbye to frenetic searching with key storage that suits your needs and matches your home's style
Full StoryFLOORSChecks, Please! 13 Choices for Checkered Floors
Checkerboard Patterns Go From Casual to Ritzy, From Marble to Grass
Full StoryDECORATING GUIDESPattern Focus: Buffalo Check
This farmhouse-friendly pattern has a wide range of uses in the home
Full StoryCONTEMPORARY HOMESMy Houzz: Check Out the Curves on This Cliffside Home
Circular forms star in a home on a Washington gorge, from the boulder pile downstairs to an exterior side with nary a straight line
Full StoryREMODELING GUIDESRanch House Remodel: Installing the Interior Finishes
Renovation Diary, Part 5: Check in on a Florida remodel as the bamboo flooring is laid, the bathroom tiles are set and more
Full StoryBATHROOM DESIGNShould You Install a Urinal at Home?
Wall-mounted pit stops are handy in more than just man caves — and they can look better than you might think
Full StoryBATHROOM DESIGNHow to Install a Toilet in an Hour
Putting a new commode in a bathroom or powder room yourself saves plumber fees, and it's less scary than you might expect
Full StoryKITCHEN BACKSPLASHESHow to Install a Tile Backsplash
If you've got a steady hand, a few easy-to-find supplies and patience, you can install a tile backsplash in a kitchen or bathroom
Full StoryMore Discussions
dekeoboe
