Boric acid - SO confused!
Posted by melaska (My Page) on
Tue, Nov 13, 12 at 23:25
I've been researching all over and am finding conflicting info.
We are all shelled in...we have mold growing in some areas of the wood studs. We've had a horribly wet summer here in Valdez, Alaska.
I came upon a solution to TREAT mold: (From eHow.com)
1/2 cup boric acid powder
1/2 cup white vinegar
1 cup water
Here's a solution to PREVENT: (eHow.com)
Combine one part hydrogen peroxide with three parts water in bucket. Stir thoroughly.
Add 2 cups boric acid for every gallon of the water/peroxide mixture and stir thoroughly.
Then I see a 2-year old thread on Gardenweb where someone told a poster that you cannot store peroxide mixed with anything in a closed container.
We were planning to put the mixture in a Hudson sprayer so isn't that a closed container??? Or if I should mix the solution in a regular spray bottle?
We are getting the appropriate half mask respirator with splash goggles and a P-100 cartridge filter. I gave the supplier the MSDS info for boric acid.
We are planning to spray the 4.5' high crawl space w/plenty of ventilation as we do so. We also plan to put in reinforced 10 ml sheeting.
A question I was asked by someone: "Aren't you worried about all those boric acid fumes seeping up into your house?" Is that an issue?
Thanks for any help!
RE: Boric acid - SO confused!
Not an issue on the fumes.
A "closed container" is an unvented one. The h202 will probably bubble. If in a closed container, it could explode. But, you might not need to pump your system....
Just vent as needed.
