JOIN NOW LOG IN
Window heads/lintels over Hardiplank- How to?
Posted by fish7577 (My Page) on
Wed, Nov 4, 09 at 21:57
Did anyone put window lintels/heads above their windows when using hardiplank siding? I've found that there are vinyl, fypon, and other urethane/foam products (Apex is one). When placing above the windows, would the hardiplank be placed right down to the top edge of window, then the head somehow mounted over it? Would the head/lintel be placed, then cut the siding around it? I'm trying to figure out the best way for looks and for flashing the window adequately. I plan to put 1x4 around the sides and bottom of the window, likely out a PVC 1x4 like Azek or Versatex. Do I need it on the top too, then mount the header to that? The heads would be approx 9" high.
What about keystones in the center? It think it would be cheaper to buy stock length, cut the center, then cover the cut with the keystone. I wasn't sure if keystones would look right on a hardiplank house. I always imagined them for brick houses in place of a masonry keystone. Any thoughts?
RE: Window heads/lintels over Hardiplank- How to?
The manufacturer should have clear instructions. Apparently people will put a simulated masonry keystone on anything.
The only kind of trim that should ever be placed below a window is a sill nosing that projects beyond the face of a nail-fin window's frame/sill and extends horizontally under the jamb trim kind of like a real wood window.
ATW makes all kinds of PVC window trim.
Here is a link that might be useful: ATW PVC window trim
