Marshy lakefrontage...never worth the hassle?
robo (z6a)
9 years ago
Dh and I are still looking (2 years now!) for a good lakefront lot for our cottage. Or a cottage. Inventory is near zero in the area we want.
In this time only two lots have come up on our desired lake.
Unfortunately both lots (different sellers) had the same problem...they're located in little cove areas and as such the waterfrontage isn't ideal - it's marshy instead of rocky or sandy. Has anyone built in a similar situation?
Other things are great- location is A+, power to the lot, driveway in, perc test good, slope decent, exposure good. Place where house would go is elevated and not marshy. We'd build on slab so no damp basement or crawl space.
At first we crossed these lots off the list because we didn't want to deal with the marshyness but as time passes and nothing comes in the market....should we reconsider?
To make matters worse (or better depending on how much you like the environment) the municipality has shoreline development rules - 65 foot setback from water for building and "minimal" disturbance to vegetation and grade within that setback. So I have a feeling they wouldn't take too kindly to me dumping a bunch of boulders at the shoreline and building up a lawn there. Not that I need a lawn...so I've been considering a boardwalk to the water or something.
The waterfrontage is ok once you get past the marshy bit...
The lake itself is rocky, clear and deep.
Here you can see the lot (outlined in black) and how the shoreline dips in a bit which makes it worse than the lot immediately to the left. It's 2 acres.
Municipality rules:
The lot has a moderate slope down to the lake but nothing too steep (can you tell this is Canadian from the picture??)
This post was edited by robotropolis on Wed, Nov 5, 14 at 19:52
worthy
robo (z6a)Original Author
Dayton Architects & Building Designers · South Barrington Architects & Building Designers · Westminster Architects & Building Designers · Winchester Architects & Building Designers · Beavercreek Home Builders · Chula Vista Home Builders · Kaysville Home Builders · Prichard Home Builders · Browns Mills General Contractors · Channelview General Contractors · Mineral Wells General Contractors · Mountlake Terrace General Contractors · Pacifica General Contractors · Shorewood General Contractors · Baileys Crossroads General Contractorsmattypies
Beemer
User
ken_adrian Adrian MI cold Z5
