| My new construction, brick, galvalume roof, story and a half home, has three gable ends. Ridge vents will run along the roof, with perforated hardy board soffets. We have three standard vinyl round gable vents ready to install also. My builder suggests that we use them as purely decorative (no hole to make them functional).
I live on the gulf coast, hurricane country,...one friend said gable vents can let in water during heavy winds. But these vents are new and hopefully engineered to stop wind driven rain,....I'd like some extra ventilation.... thoughts? |
| I'd love to see answers/opinions on this, too. Our plan calls for 4 vents on either side of the roof but with ridge vents, 2 powered roof vents and a huge attic I wonder if we can save the $$... |
- Posted by hollysprings (My Page) on Tue, Nov 6, 12 at 9:44
| Ridge vents work in conjunction with eave vents. Doing anything else is counter productive for roof ventilation. No gable vents. No power vents. The aire flow is from the unobstructed eaves (with insulation chutes to maintain clearance) through the underside of the roof and out the ridge. However, in warm climates, having a sealed attic with zero venting would be the best choice for the home. Especially if you have ducting planned for the attics. |
- Posted by landngarage (My Page) on Tue, Nov 6, 12 at 9:55
| I think we are past having a "sealed attic" at this point. And this being a story and a half, the "attic" is a rather small area at the very peak of the roof. Roof trusses are 2x8's... the cross ties that define the small attic are 2x8's also. We will have insulation chutes/spacers between the roof and the fiberglass. A silver galvalume roof will be used. |
- Posted by energy_rater_la (My Page) on Tue, Nov 6, 12 at 11:49
| baffles in rafter bays dedicate pathways for cooler air to enter soffit ventilation areas. why builders mix ventilation strategies in there are three methods of venting gable end venting. soffit and ridge venting soffit and passive vents some areas are outlawing pav's, with good pav's..never a good idea for the person who lives undoubtably unvented attics benefit hurricane areas but for those who don't go that route, proper attic Georgia Pulls the Attic-Ventilator Plug Building science target. The money that would have been spent purchasing and installing one of these attic fans could pay for a more cost-effective upgrade, which would include more ceiling insulation and proper air sealing. best of luck. |
- Posted by landngarage (My Page) on Tue, Nov 6, 12 at 12:10
| I have called my builder. The gable vents will be installed as decorations only. I will redouble my caulking and insulation efforts between my little attic and the AC'd living space. Thank you! |
- Posted by athensmomof3 (My Page) on Wed, Nov 7, 12 at 11:55
| Ha. Just built in Georgia with power vents. Passed code. Not solar power. I understand the thought process behind no power vents (but didn't read them until after they were installed and we moved in). However, we moved in in late July. Our upstairs heat pump never kept up. Went on for several months and was troubleshooted (or troubleshot;)). I was in the attic and noticed the roof vents were never hooked up to electricity. They were hooked up, a/c immediately cooled and worked much less, bill went down 350.00. Wonder why? Temperatures were consistent. We do have quite a bit of attic insulation but only blown in cellulose (a lot of it though). Perhaps that sealed any holes where air could be sucked in. It was not the result I was expecting but am very glad for it. |
- Posted by energy_rater_la (My Page) on Wed, Nov 7, 12 at 13:33
| atricle is recent. would not have been in effect in july. good for you landngarage. best of luck. |
