| If you live in an area with major natural storms, here's some thoughts on planning your new or existing home:
--Insist on hurricane clips for upper floor and roof framing (and if you live in seismic areas insist on foundation tie-downs);
Don't forget to start and maintain your generator on a monthly basis as a minimum. You should have a 5-gallon container of extra gasoline available in case you cannot immediately go out for extra fuel, if needed. Hope this helps for future planning. |
- Posted by Renovator8 (My Page) on Thu, Nov 1, 12 at 7:33
| The IRC requires all rafters and trusses to be connected to top plates to resist the wind up-lift forces shown in Table R802.11 for different spans and exposures. In a low exposure wind area a standard hurricane tie is required but in a high exposure wind area it might need to be 2 or 3 times stronger. |
