Hi all, I am not building a new house, but I am considering a remodel. What kind of housewrap did you use under hardieplank or other fiber cement siding. Thanks volvo
Thanks for the reply ogoopogo. I have been getting estimates and some of the contractors were trying to sell us on other wraps that made the price more expensive. I have seen tyvek on just about every addition or new construction I have come across so it seems like everyone else think its a good product. volvo
I easily prefer Typar over Tyvek. Greater rip strength, not blinding white, and less noisy. Works good too! Price wise they're even; or at least should be very close.
Tyvek or a quality equivalent should be fine as with brick you have an air space, so unlike stucco, the housewrap wont be contacted causing moisture behind the wrap. With stucco, a double ply underlayment is best because the scratch coat being cementious based contacts the first ply causing moisture to build behind the first ply, but is caught by the second where the moisture runs down and out by way of a weep screed. Your biggest concern will be proper flashing of all openings along with keeping the proper drainage plane typically weep holes at the starter course of the brick to let moisture/water run out at the base. A good way to see what works in your area is to visit projects that are current by reputable builders and seeing what they are using. Stop and ask as most will be more than happy to advise.
Tyvek, Typar, R-Wrap, and Weathermate Plus are all non-woven, non-perforated wraps with minor differences and are substantially superior to the woven/perforated wraps.
But because these membranes are stapled and taped in the field and this creates a space between the membrane and the sheathing, they rarely perform as advertised. The location where they frequently fail is at window openings in spite of the care taken to wrap the edges into the openings and seal them.
A far superior product is a liquid coating that is applied in the field or in a factory. Field applied products are explained in the link below and the dominant factory coating is called Zip System sheathing by Huber.
Home builders are slow to change but these liquid products perform so much better than plastic wraps that wraps will eventually become obsolete in home construction as they have in commercial construction.
People have told me that I must be trained and licensed by the manufacturer to apply liquid WRB's but that is not true. STO Gold Coat can be applied with a paint roller, brush or sprayer by anyone, but it is a commercial grade product so it is sold in 5 gallon containers.
volvo_85Original Author
buzzsaw
Salisbury Home Builders · Barrington General Contractors · Conneaut General Contractors · Gallatin General Contractors · Galveston General Contractors · Grand Junction General Contractors · Marinette General Contractors · Mashpee General Contractors · Milton General Contractors · Panama City General Contractors · Rotterdam General Contractors · Saint George General Contractors · Sheboygan General Contractors · Troy General Contractors · Walker General Contractorsdixiedoodle
vancleaveterry
sierraeast
vancleaveterry
sierraeast
evans
auntrainy
User
