Melted siding
Posted by madmacker (My Page) on
Fri, Oct 26, 12 at 12:03
Our house is 5 years old and we just noticed that the siding behind our built in oven is melted. Our builder was very incompetent and was eventually fired but I am wondering what he might have done/not done for this to happen. I really don't want a house fire so need to get this figured out. Thanks.
RE: Melted siding
A lot of melted siding is caued by the reflection off of a nearby window... even the neighbors window can cause this. I see this phenomena every once in a while. And at certain times of the year, at certain times of the day, if I walk behind my own home, I get a very hot burning sensation on my face. I found out that it was the reflection off of the window.
RE: Melted siding
It is rather unlikely a zero clearance residential oven can generate enough heat to affect exterior siding.
Their is still some type of insulation and sheathing in the path.
RE: Melted siding
Just asking....because I saw this happen to someone's house... Was someone using a grill too close to the house?
RE: Melted siding
No, it is nowhere near where anyone was using a grill. I think it is melting from the oven somehow but not sure why. Like I said, our contractor might not have put the needed material behind the oven. Not sure what should be behind it. Guess we are going to have to pull off the siding and see what's there.
RE: Melted siding
" Guess we are going to have to pull off the siding and see what's there."
It might be easier to pull the oven.
At least they are designed to be removable for servicing.
RE: Melted siding
An oven that would melt any construction material is defective so you should call an appliance repair person. If the melted siding (PVC?) is on the outside, it was likely the result of an exterior heat source unless the wall has no exterior sheathing or interior finish.
RE: Melted siding
I would agree completely with Renovator8, house would have to mess construction wise for the oven to melt exterior siding.
RE: Melted siding
Google melting siding and you will see that this problem caused by windows is a real and increasing problem. Like I said, I see it about once or twice a year, and it is caused by the relection from a nearby window.
Ovens are insulated themselves. I don't think they get very hot on the outside. Just touch the oven door... cool to the touch. look for a nearby window as a culprit.
RE: Melted siding
Or a neighbors window if the homes are close together!
RE: Melted siding
As noted above, melted vinyl siding from reflection is not uncommon. Lots of pics.
RE: Melted siding
Okay, well thanks for everyone's help on this. Our window guy will be back out in a week or two to replace a couple of windows and I will check with him then and see what he has to say about the whole thing. Not sure what can be done about it if it is the windows.
RE: Melted siding
"Not sure what can be done about it if it is the windows."
It is NOT usually YOUR windows, it is a neighbors window.
RE: Melted siding
Well, our closest neighbor is about 1/4 mile away so I can't blame it on them!!
RE: Melted siding
If you have an L - shaped part of the home, it COULD be coming from your own window that is located on the wall that is 90 degrees away from the part of the home that is getting melted.
Hope that makes sense.
