Wed, Sep 26, 12 at 15:16
| What level of detail should I expect in the
architect's completed plans? I'm poised to send them out to builders for bids. Among the 10 large sheets are a foundation page, a roof page, and a page that shows a large amount of detail on the framing. But there's no page that details all the plumbing piping. (The water heater is spec'd in the notes, along with specific bathtub and shower types we wanted.) Is this something that the builder creates, or leaves to the plumbing subcontractor to figure out? |
- Posted by Renovator8 (My Page) on Wed, Sep 26, 12 at 15:32
| Plumbing is like electrical work - it is closely controlled by codes so the plumber figures out how to do it using the architectural drawings for fixture locations and using the structural framing plans for the pipe runs and the plumbing inspector determines if it is acceptable. If there is a problem running pipes or the vent termination will be in a sensitive location, the architect or engineer might be consulted. |
- Posted by virgilcarter (My Page) on Wed, Sep 26, 12 at 16:36
| Renovator8 is correct! Generally speaking, plumbing fixtures and finishes are called out in the drawings or specifications, usually with a chart, but sometimes with notes on the drawings. If there are any special plumbing requirements, i.e., clean-outs, floor drains, sump pump, special collection and drainage, etc., these should also be called out. After that, it's up to the plumber to install and meet code requirements which will be verified by the local building official when plumbing work is completed. Piping sizes and runs are seldom shown unless there is an unusual condition coupled with them. Good luck! |
