CertainTeed lap siding looseness/wavy
n123
More Discussions
Hi,
Our GC is installing 5 1/5" CertainTeed smooth lap siding on our 1920 home but the boards seem to be much looser than I would have expected. Most boards, you can push on the bottom of them and they will have 1-2mm of movement (bounce). It is a blind nailing installation with the normal 4" exposure. Is this amount of movement normal?
The sub tells me that it is because my house is old and the existing conditions don't allow the boards to lay flat. After looking closely at how they are installing the boards, I actually believe this is due to their installation method. They are driving the nails at around 1/2", rather than the recommended 1" nail line and they are often times over driving the nail and it ends up being sunk, rather than proud to the surface per the CT install spec. They continue to insist they are doing it correctly and that they have been doing it this way for years, "without problems".
In addition to the looseness, parts of the siding are also "wavy". I also think this is due to over-driving the nail and forcing the siding tight to the original frame rather than sitting straight on the OSB layer and letting it buffer out irregularities.
Has anyone installed CT or Hardie on an old frame with new sheathing? Do your boards sit flat?
I'm hoping someone may be able to offer their results on a similar application, right now it is a computer nerd (me) vs a bunch of construction guys.
Picture attached showing the nail line, this board was removed for an alternate reason.
This post was edited by n123 on Thu, Sep 19, 13 at 8:16
millworkman
millworkman
Bull Run Architects & Building Designers · Arlington Home Builders · Chula Vista Home Builders · Immokalee Home Builders · Rossmoor Home Builders · South Hill Home Builders · Belleville General Contractors · Buena Park General Contractors · Claremont General Contractors · Cumberland General Contractors · Everett General Contractors · Havre de Grace General Contractors · Maple Heights General Contractors · Nashua General Contractors · Williamstown General ContractorsChrisStewart
bevangel_i_h8_h0uzz
