| This is an existing home but so many of you are good at tweaking plans that I thought I'd post here.
Right now our downstairs guest bath is in the farthest corner of the house almost completely opposite of the entertaining area. I'd love to figure out a way to squeak out a 1/2 bath from the two closets and laundry room area. To make it worth while, the entry door will need to be near the foyer. You can't see the full plan here, but the entertaining area is an 18 by 30 room to the right of the kitchen. Here is a close up of the hall, laundry and closet area. Thanks for looking. |
| Are you willing to lose your utility sink? If so, it is a real easy insertion. |
- Posted by mydreamhome (My Page) on Sun, Aug 26, 12 at 0:19
| How deep is the closet that is next to the washer/dryer? Have you thought of making it deeper and utilizing it as a 1/2 bath? That would allow you to keep the coat closet and the sink/counter space in the laundry--they would just be shorter. |
| Both closets are two feet deep. Are you suggesting that the entrance to the bath go through the family room closet or opposite the basement door or through the hall closet? Depending on the configuration, I probably won't miss the utility sink too much. |
| Bumping up, hoping to get some specific suggestions. Would moving the wall between the front closet and laundry room leave enough room for a bath? Keep in mind there is a window in the laundry room that limits how far we can expand the closet. Thank you for looking. |
- Posted by mydreamhome (My Page) on Tue, Aug 28, 12 at 9:30
| You've got 2 closets and a laundry room to work with to make this 1/2 bath happen. Luckily there is plenty of space to create what you desire and in numerous configurations. Here are the ones I see: Using the hall/foyer closet-- Using the other closet that faces the family room--you could go 1 of 3 ways: 1) Extend the family room closet current back wall into the hall closet & the counter space where the utility sink is and place the toilet there in that space, then the sink backs up to the washer and the entry door goes on the hallway side. You enter looking at the sink with toilet to your right. With this configuration, you could technically still have 12" or so available on the laundry room side to put in tall storage where the sink currently is if you limit the toilet width to 3' which is pretty roomy. If you prefer the door on the family room side, you could do that and I would flip the sink & toilet so you're not staring at a toilet through the doorway. This option also allows you to keep counter space in the laundry. No interference with the window and you still get to keep a decent sized hall/foyer closet too. 2)Extend the back wall of the family room closet into the laundry and hall closet 3'. The sky is the limit on your toilet/sink/entry door arrangement. You keep some counter space in the laundry and no interference with the window, still a decent sized hall/foyer closet. However, you do lose the sink in the laundry and you lose the option of having the 12" deep tall storage in the laundry. 3) Extend the wall behind the washer and dryer into the laundry room 3', extend the back wall of the family room closet in 1' so now they're even leaving a 3' deep space on the family room side. The utility sink goes away and you just have counter space in the laundry. Then install a long 1/2 bath on the family room side with the sink & toilet opposite on another and you enter it off the family room. You should still have space left on the end for a decent sized closet that would back up to the washer/dryer area, you keep a decent sized hall/foyer closet, you still have counter space in the laundry, & no window interference. However, you lose the option for the 12" deep tall storage in the laundry and you lose the sink. My design program is down right now, but if I can get it going, I'll draw it up for you. Hopefully the descriptions above give you enough of an idea of what I'm talking about. Hope this helps! |
| I would not put the entrance thought the family room. Put it though the hall. Combine the hall closet and the 2' space in the laundry room. This will get you plumbing too. with 4' x6'8" you should have plenty of room. |
