| Thanks for a thoroughly detailed, extremely helpful post! Great advice! (Doesn't it feel awesome to be so smart and organized?!!! haha) |
| Excellent! Congrats! I had always read this, and so did my version of this (not 400 pix, but at least some pix), and it did actually help when I was looking at my vent hood. I've completely gotten into the habit of just snapping pix of whatever new thing I see has happened that day/week/weekend, and it helps to chronicle the (very slow) progress, as well. Great Great advice!! once they close the walls, that's it! And we have a smooth finish on our drywall, too. |
| I absolutely second wwwonderwhiskers advice! And, if your digital camera will take videos as well, shoot very methodical videos of each room starting in one corner and working your way around the room in a clockwise or counterclockwise direction. Then take your overlapping still photographs immediately after taking the video. It is often much easier to figure out what is what in a video. But still photographs will be sharper and show more details. With a combination of videos and still photos taken on the same date, you can use the video to help you orient your still photos and figure out what you are looking at...especially if you take the time to tape numbered squares of paper up around the room before making videos and shooting photos. Our "open wall" photos have saved us a couple of enormous repair bills as well. And, when we got ready to hang our TV, it was nice to be able to look at the photos and see right where the studs and extra bracing were located. It is also nice when you start to hang a picture on the wall, to KNOW, that you're not fixing to accidentally drive a nail into a hidden pipe. Oh, especially if you're going to have a slab foundation, don't forget to photograph where all the pipes and stuff run UNDER the slab before the concrete gets poured. And don't forget to take pictures of the outside of your house before the sheathing is put on. If your house has more than one floor, be sure you have pictures of everything that runs thru the space between the two floors as well. Water from a leaking pipe or waterline can often travel along joists quite a way before dripping through the ceiling sheet rock and showing up as a wet spot. Rather then unnecessarily tearing out a bunch of sheet rock, It helps to know where the water COULD be coming from.
- Posted by energy_rater_la (My Page) on Mon, Aug 22, 11 at 14:27
| you should add to your faq. |
| This is a great post! It provides advice on the right level of detail for suggested pictures to take and the approach in order to not get lost in all the pictures. I only wish I had been provided this information when we were building our home. We took 200+ pictures (which have provided invaluable), but I wish I had taken double the number. I missed out capturing close-ups with tape measure. We made "notes", but those have proved less useful. It WILL take some time and effort, but as noted in the example above it can save you a lot of time, frustration and money. btw, we chose to print a copy and put into a notebook, so we could quickly reference in the build process when questions came up with a sub or the builder. In a related point, we used digital pics and written comments to documents any issues during build process. It made it easier to communicate our areas of concern ... in a manner the builder could share with a sub, which they did often. We even started providing copies of our work issues grouped by sub's to essentially provide builder a checklist for his subs. That part worked great and was appreciated by builder (just stay net and to the point, leave "emotion" out of it). Additional comment would be to take the same level of pictures where sprinkler lines are run in the yard and/or plumbing lines for any pool. We did both of these and they can be equally beneficial ... Easier to take "more" digital pics and delete (or not use) vs "wish" you had taken more ... |
- Posted by frozenelves8 (My Page) on Mon, Aug 27, 12 at 2:10
| great info |
| Please snap away! I'm usually so busy building that I forget to take progress photos and pay for it later trying to puzzle out where that hidden return or vent was. Of course, your photos make me wonder why the builder was using three and even four top plates when one and two are all that's necessary and bucking 2x4s three times per stud cavity (unnecessary) while not protecting the electrical cable as required. |
