Pouring concrete in cold weather
Posted by kidhorn (My Page) on
Fri, Aug 19, 11 at 12:45
I'm getting a room addition to my house and part of the addition is a cellar. It will be about 7' below grade. I've been working on getting the addition since May and now found out I need to apply for a variance and the soonest I can get back to getting permits moving is around Thanksgiving.
So it looks like the soonest construction can start is likely during the winter. I live in Maryland.
My question is...
Is it OK for my contractor to pour and set concrete during the winter? Should I wait for spring?
RE: Pouring concrete in cold weather
With reasonable precautions there will be no problem.
Concrete generate heat as it cures, and some insulation (even plastic to prevent air movement) can often keep it above freezing long enough to set up correct;y.
Worst case it need to be enclose din plastic and torpedo heaters used to keep it warm.
