| http://www.energyvanguard.com/blog-building-science-HERS-BPI/bid/25546
/4-Pitfalls-of-Spray-Foam-Insulation
this is why the installer and his/her
best of luck. |
| Poor thermal results from unskilled spf application is only half the story. Putting a chemical factory on your driveway run by a semi-skilled operative who may have started yesterday, then having him pump your house full of outgassing materials is taking a leap of faith. Add outgassing to the effects of sealing your home and you may have a recipe for problems, especially for the chemically sensitive.
- Posted by energy_rater_la (My Page) on Fri, Aug 3, 12 at 21:20
| outgassing comes from adhesives, carpets and many other things. I've had chemically sensitive clients who got sick after buying a new laptop... to hang it all on foam is kind of a leap of its own. this is well explained in the post of worthy's. thanks for the link worthy. don't think that foam is a cure all or miracle personally I think there should be a site have a good weekend everyone. |
| I have seen most of those instances. I think one of the biggest BS arguments installers push is that you do not need as much thickness/ r value that energy code states because SP is better and eliminates air leaks. While this is true, r value is r value. It does not matter how much better it reduces air flow, not shooting the required value is still a code violation. With the 2012 IECC coming out, it now greatly increases air sealing requirements for homes, which will require people not using spray foam to focus more on air sealing, which will even the playing field. Besides, something most people do not consider is codes are the minimum a building should be built too. The lowest acceptable. So why not go above them anyway? Good little article. |
- Posted by energy_rater_la (My Page) on Sat, Aug 4, 12 at 21:13
| I have that R-value discussion with my clients. and sometimes have the R-value argument with foam companies. just because foam stops air infiltration when properly installed does not mean that 2-3" average meets code. foam companies can't just make up a quanitive value for their product, and expect code to except it. if that happened..every product would have a k or q value. for the public to realize that the builder so lzerarc, you also see foam pulling away from I've looked at so many foam jobs that I can tell |
| I am not a builder, but an architect, so unfortunately I do not get to pick the foam company typically. Also do mostly commercial projects too, with some residential. However there is one go to company that will always do a good job at foam, sends all of their guys to training every year, etc. I do not see a lot of foam on my jobs bc I typically do not spec it, rather go with blown products instead. But I have seen foam on other projects where we were called to check it out. Most of the time it was a bad mix or something, so I usually have it removed and reshot. Most cases the 2nd time its fine...imagine that! |
| Related Question: If in the future someone needs to snake wires or plumbing through wall, ceiling, or floor cavities, can you do it with foam insulation? or do you have to remove a lot of wall board? Also, is it difficult to remove old sprayed-in insulation? |
