| Our trim is being done, and we've been told that the widest windowsill we can have is 2 5/8". Where we still have older windows in another part of the house, they are 2 3/4".
Our contractor said that newer Andersen windows are meant to be picture framed, which for some reason makes it impossible to have wider sills. Does this sound right? I don't know enough to assess this myself. My preference would be to have slightly more than the 2 3/4", so getting less than that is a bummer. |
| Nonsense! The image below is pulled off of the Andersen Windows website (see link below). The window unit that comes from Andersen is shown in orange. Everything in blue and green is supplied by your builder. There is sometimes a bit of disagreement about how some terms related to windows are used so, for clarity I'm going to use them as they are labeled in this diagram. It is clear to me that what you really want is a deeper "stool" ...maybe because you envision setting small flower pots on the finished window sill. The stool can be made as deep as you like. The stool fits up against the "window sill" which is part of the window as it comes from Andersen. The stool is a flat piece of wood that should be set so that the top is at exactly the same height as the window sill. (That way, your "finished window sill" is the depth of the Andersen window sill plus the depth of the stool. Make sense?) Then, beneath the stool, and at a 90 degree angle to the stool is another flat piece of wood called the apron. The apron helps to support the stool. Where the stool is fairly shallow, a piece of 1/2 inch or 3/4 inch quarter-round is usually used as finishing trim under the stool where the stool and apron meet. This finish trim also helps to support the stool. But, if you want a deeper stool, you simply choose a larger and perhaps more elaborate piece of trim to replace the quarter-round. The wider trim provides additional support to the deeper stool. If you want to go with a really wide window stool, use some metal corner braces to support the weight of the stool and then hide them with a piece of crown molding trim. And obviously, you would need to make the apron taller to keep things in scale. If you're going to paint your windows, the line where stool and sill meet is puttied in and sanded smooth before painting. If you're planning on staining the windows, The stool must be cut very carefully so that the two pieces fit together without gaps when they are glued together. Any white glue that squeezes onto the top surface should be thoroughly cleaned up at once so that it doesn't show when you apply stain. Builders like "picture framing" windows because it is very easy and cheap to do. That doesn't mean picture framing is the ONLY way to frame out modern windows. If it were, historic homes would not be able to be be updated with modern energy efficient windows while maintaining their historical look. Any reasonably competent carpenter should be able to frame your Anderson windows to achieve the look YOU want. |
Here is a link that might be useful: Andersen windows
- Posted by elizawhyza (My Page) on Thu, Jul 19, 12 at 12:42
| My spec specifically says no picture framing. I am not sure what it is, actually, but it sounds like you would need more elements to not picture frame. I did not realize that what my contractor has done is picture framing. He mentioned that the windows were set up to do them that way, but I thought that because we discussed it before, that he wasn't using the picture framing approach. The casing is about 3.5" wide. What would be the max stool that would look good with that, in your opinion? |
- Posted by elizawhyza (My Page) on Thu, Jul 19, 12 at 13:28
| OK, now it makes sense! I asked the contractor, and they are now going to cut the stool at an angle so it will be level with the sill. The way they first did it was different. The sill was higher than the stool, so I could see the entire "border" around the window that comes with the window itself. Now the stool will appear to be wider because it will incorporate the width of the sill into its surface. How much of a reveal do you like to see on the sides and top? I think I prefer to see less of the border that comes with the window. |
- Posted by elizawhyza (My Page) on Thu, Jul 19, 12 at 13:44
| One more addition here: I found a post from the window forum from a couple of years ago, and I have a follow up question. Our windows have jamb extensions on all four sides. If you read below, it sounds like with some companies you don't have to have the jamb extension on the bottom. This would allow you to avoid using a sill cap over the existing jamb extension. If you already have the jamb extension, it is ok to remove it? I wonder if it would void any warranties? clip this post email this post what is this? Posted by galefarm (My Page) on Fri, Jul 31, 09 at 15:45 Basically it depends on your taste today whether you have a sill on the window or not In most cases the picture frame approach works very well." |
- Posted by elizawhyza (My Page) on Thu, Jul 19, 12 at 14:30
| Thanks, bevangel! No, it doesn't look like the picture at all! I just did not like that the stool was lower than the sill. You could see the entire extension jamb as a rectangle around the window. They will now do it so the stool meets the sill "flush", and they are going to show less of a reveal on the other three sides. I will send a picture later. They are working now so I don't want to take a picture. I agree that the photo you sent is not the look we're going for! I have lived in several 18th C houses, and even on built in 1682, so my preference is for an older look. I want to see the trim, not the jamb. I know we need a reveal, but I would prefer to see just the angled "bevel" if you will, not the flat part of the extension jamb. My current house is only 32 years old, but it's a rambling cape that now has a cedar roof, hardy shingle on the front, and smooth hardie plank elsewhere. By no means is it a reproduction, but certain details matter to us a lot, and this is one of them! |
| Just saw your follow up posts. Are the interior sills of the windows (as they come from Anderson) angled or do they have a beveled edge? Mine (from Jeldwen) were cut square so placing a stool up against the sill would have been no problem at all. We opted AGAINST having deep finished window sills because I didn't want to be tempted to set plants in the windows. (I have a tendency to overwater my plants and end up with a pool of water under them which would not have been good for my wood framed windows.) The thread you reposted from galefarm about jamb extensions is a bit confusing because he/she talks about both the interior and the exterior window finish at the same time. I would not recommend having an exterior window sill. Even when properly sloped so that water runs off, an exterior window sill provides a place where things like wet leaves/snow can collect. On the inside, you can just apply a sill cap over the existing jamb. I would NOT remove the lower jamb without first contacting Andersen regarding whether this would void their warranty. And if their agent said that it would not void the warranty, I'd want it in writing with a statement that the agent had the authority to bind the company. Window companies can be VERY picky when it comes to their warranties. |
- Posted by elizawhyza (My Page) on Thu, Jul 19, 12 at 15:33
| They are beveled. The carpenter is cutting the stool so it lays on the bevel of the sill. It looks really good, and you don't see the extension jamb at all, like an old-fashioned window sill. Thanks, again, for your help. |
- Posted by Renovator8 (My Page) on Fri, Jul 20, 12 at 5:26
| It's difficult to follow this discussion. A window "sill" is the exterior part of a window frame that slopes to shed water. Modern windows have very small low-sloping sills and can be "picture framed" which means the same exterior casing trim is used on all 4 sides. This often causes leaks below the window and should be avoided. Instead use a PVC "sub-sill" to create more projection, a better "drip-edge", and a place for the jamb trim to terminate. The lower trim on the inside is called a "stool". It creates a better seal at the bottom sash and a narrow tapered "apron" trim is placed below it. Modern windows are no different from older windows in that the stool can be added or omitted. When it is omitted the casing trim is the same on all 4 sides like a picture frame which has a 60's modern/utilitarian/office appearance. I'm not sure what is meant by beveling. A photo would be helpful. |
| As I said, variations in what is meant by some of the terms related to windows can cause confusion. That's why I started my response with a labeled diagram taken from Andersen Window's website showing the interior of a window and then used the terms as Andersen Windows used them on their website. OP did not have any issues with the exterior trim out of her windows. She just wanted a wider flat surface on the INSIDE of her windows so she could set plants/knickknacks in the window. Since OP (and apparently her builder) were able to follow the discussion well enough to solve OP's problem, whether the particular part of the window trim that was in question is properly called a "stool" or a "sill" - or something else altogether - seems irrelevant. I'm sorry to have confused you tho. Hopefully if anyone else has a similar problem, they'll find the diagram helps to clarify things. |
- Posted by Renovator8 (My Page) on Fri, Jul 20, 12 at 11:51
| The issue here is how an Andersen window is detailed differently from a traditional window which is difficult to discuss because Andersen makes many different designs and apparently the model is not identified. For an Andersen Woodwright double-hung window the statement that newer Andersen windows are meant to be picture framed is true for the exterior trim but not the interior trim. The use of a stool vs Picture frame trim is entirely optional. But I suspect the contractor either misspoke or was misquoted because he was probably saying that the presence of a weather lip at the bottom interior edge of the sash allows the window to have "picture-frame" trim because a stool trim is not needed to seal the window sash as it normally is on an older window. It is also true that the presence of this permanent weather stop makes Andersen's standard stool trim about 3/8" shorter. |
- Posted by Renovator8 (My Page) on Fri, Jul 20, 12 at 15:21
| The confusion that seems to have arisen here appears to be due to a misunderstanding of why modern windows have an integral upturn or weather stop at the bottom interior edge of the frame/sill. It is not for the purpose of accommodating "picture frame trim" although it does take the place of what originally served as a weather stop: a stool trim added in the field. The reason these upturns were added was to be able to get higher air/water penetration test ratings with the basic unit since a field applied stool would be ignored in the modern test, would not stand up high enough to be very effective and would not accommodate a weather strip. So today windows have improved weather/air penetration ratings but pretty dumb looking stool details. Windows made for higher wind areas have even higher upturned weather stops. Unfortunately, window designers care more about how a unit will fit in a shipping box than how it will look when trimmed in the field. It takes a good carpenter to make a modern window look good no matter what you paid for it. |
