Should I use prefinished hardwood or not?
Posted by heartspeace (My Page) on
Tue, Jul 24, 12 at 4:03
My plan was to use prefinished hardwood. But then others pointed out that if it's finished in the house that there will be no cracks, and if there's no cracks there's no place for spills to go.
You are a wonderful community. I hope you are willing to share your thoughts on this.
Hp
RE: Should I use prefinished hardwood or not?
You do not want "cracks" or a place "for the spills to go" as that will cause many more problems. The reasons for using prefinished or site finished are not at all related to that statement and for someone to give you that advice is really inconceivable in my opinion.
Wood of any variety expands and contracts with the annual swing in humidity levels. Yes, site finished floors do that too, and guess what happens to the space in between the boards when that happens? The finish isn't elastic. All site finished floors will have microscopic cracks in the finish in between the boards. If the humidity swings are enough, such as someone doesn't use a humidifier in the winter and AC in the summer, those cracks can be visible to the naked eye. Homes constructed before the turn of the last century often have quite substantial gaps between the boards because of the large boards used. The larger the board, the more potential it has for movement in a non humidity controlled environment. You cannot change the physical nature of wood simply because of the location that the finish is applied. Whomever thinks their floors are one solid sheet just because they were site finished just doesn't understand basic science.
I think heartspeace may have been thinking of the beveled edges of prefinished hardwood, rather than the gaps from humidity changes. Our previous home was mostly site finished, but one room had prefinished hardwood. Those small beveled edges did make it significantly harder to keep clean. Gunk would definitely build up in there over time.
As with everything there are trade offs.
The prefinished is cheaper and faster to install. The 'engineered' versions can be more stable (smaller changed due to humidity).
One other downside to the prefinshed - engineered hardwoods is that some can only be refinished once or twice before the entire floor has to be replaced (usually not a big deal unless you are really planning for the long term).
And finally there is an aesthetic difference. The beveled edges give the prefinished floors a slightly different look.
Not all prefinished floors have beveled edges. The more moderate lines of Kahrs flooring have straight edges and ends. We loved our Kahrs floors in our last house (red oak) and hope to have them in the home we are building.
I'd use pre-finished wood.
The finish is a lot higher quality than site-finished. It's factory controlled, applied in a clean environment and typically UV cured aluminum oxide.
Compare that to polyurethane mopped on by some unskilled laborer.
It's perfection compared to streaky surface with various embedded dust particles...
Jrldh,
See that was my thoughts exactly. I really thought that the pre-finished and have that installed into the house would be the epitome of where I wanted to go. Yet I was worried about the cracks and spills going down the cracks warping the wood or otherwise damaging it in repairability or even inconveniently
Jrldh is right....
Prefinished now surpasses sand and finish and the trend is only growing... See how its done here, it will make you feel better about your concerns....
Here is a link that might be useful: Finishing Process
hddana, Thanks for the recommendation on Karhs. I have not heard of that brand. I do not like the bevels of most prefinished floors, so I will look into Karhs. Do you know if they are available in showrooms or it it only online?
I can always tell the difference between pre-finished and site-finished, and I always prefer site finished. Plus, you can custom mix your stain color with site finished. It is the norm for high-end builds and renos in our area.
nini804, around here site finished floors are considered more upscale as well. It would be difficult to find a higher-end home with pre-finished hardwood flooring.
I've lived with laminate, engineered hardwood, solid pre-finished hardwood and for the new house we'll have site finished everywhere except wet areas. :)
Concerns over liquids soaking in-between bevels/boards are probably overblown unless your family frequently spills stuff and lets it sit until somebody else gets around to cleaning up hours later.
I have prefinished engineered and it was not high end but it's really held up well all things considered. Next house though I'm leaning towards site finished. I want all wood except in the baths and I want to be able to refinish it as needed without having to replace it.
Site finished all day and twice on Sunday. With absolutely no offense to those with prefinished floors, I just don't buy the marketing that these floors hold up better. I'm sure they're a fine product, but I see scratches on them everywhere. And I hate the bevels. And I'm not sure they're that much cheaper.
You don't see many high end homes with them, and there are reasons why that is the case.
We're getting prefinished flooring - it's not in yet. I don't know anything about what might be better or high end or whatever but where we're getting it - they do custom staining.
I've read heaps about this online and as with so many things - there's just no clear answer. My builder deals with this place and I like it, so that's what we're doing.
Good luck.
I never realized that the class warfare that is being raged is now applying to those who prefinished wood and those who site finish wood. :O
'Seriously' though, I really didn't know that there was this type of eliteness with site finished flooring. Don't get me wrong it's fine, I guess, it doesn't bother me anyway. I just want to floor that looks nice and I'm not paying the arm and leg for, and is easy to maintain. I just found out a lot of hardwoods exotic especially if you don't move everything around in the room and what's ever underneath an object is going to stay lighter than the rest of the wood that is exposed to UVA rays. Crazy crazy crazy this world of wood. Almost makes you want to stick to carpet.
I think I'll find the a nice wood I like and if light makes marks by things like pieces of furniture that arent moved then so be it, if it scratched then so be it, and if it gets warped a little bit by something I forget cleanup in the next five seconds well, s be it. After all we have to live.
Now if I can find a good store and a good brand of Tiger Woods I'll be happy. Oh ye a superb installer and my area would be great also.
hp
LOL - on the "class warfare over site vs prefinished!"
I was thinking the same thing. Around my neck of the woods there are some higher priced homes using the prefinished hardwood. I used it in my home because it fit the style of the home we built - sort of a rustic, cottage style and our flooring has knots, dings, and the handscraped appearance which would have had an astronomical cost to have done to a site finished floor.
If you have picked out a prefinished floor you like - go with it!
