Heating/cooling vents are all under our windows...mistake?
threeapples
MOST POPULARSo You Say: 30 Design Mistakes You Should Never Make
Drop the paint can, step away from the brick and read this remodeling advice from people who’ve been there
Full StoryFLOORSIs Radiant Heating or Cooling Right for You?
Questions to ask before you go for one of these temperature systems in your floors or walls (yes, walls)
Full StoryDECORATING GUIDESFrom Queasy Colors to Killer Tables: Your Worst Decorating Mistakes
Houzzers spill the beans about buying blunders, painting problems and DIY disasters
Full StoryBATHROOM DESIGN5 Common Bathroom Design Mistakes to Avoid
Get your bath right for the long haul by dodging these blunders in toilet placement, shower type and more
Full StoryREMODELING GUIDESGet the Lighting Right: 8 Mistakes to Avoid
See How These Great Interiors Found the Right Lighting Solutions
Full StoryGREAT HOME PROJECTSHow to Add a Radiant Heat System
Enjoy comfy, consistent temperatures and maybe even energy savings with hydronic heating and cooling
Full StoryEXTERIORSGreat Design Element Our Grandparents Knew All About: Awnings
This time-tested feature for shading and cooling is enjoying a resurgence
Full StoryGREEN BUILDINGInsulation Basics: Heat, R-Value and the Building Envelope
Learn how heat moves through a home and the materials that can stop it, to make sure your insulation is as effective as you think
Full StoryFLOORSWhat to Ask When Considering Heated Floors
These questions can help you decide if radiant floor heating is right for you — and what your options are
Full StoryFLOORSFloors Warm Up to Radiant Heat
Toasty toes and money saved are just two benefits of radiant heat under your concrete, wood or tile floors
Full StoryMore Discussions
LuAnn_in_PA
jolsongoude
Ronkonkoma Architects & Building Designers · Palos Verdes Estates Design-Build Firms · Artondale Home Builders · Lincoln Home Builders · Belleville General Contractors · Bremerton General Contractors · Hanford General Contractors · Markham General Contractors · Medford General Contractors · Newburgh General Contractors · Phenix City General Contractors · Post Falls General Contractors · Spencer General Contractors · Waianae General Contractors · Waianae General Contractorsjolsongoude
gbsim1
renovator8
Roney Joseph
chisue
Mark Bischak, Architect
JJ
John Smith
