Hi everyone.
It's been several years since I've taken the time to post here. I've been very busy building our dream home, while also trying to balance my time between work and family.
It's been a long 6 years but I finally see the end of our build getting close. We hope to be in the new house by the end of this year.
You're probably asking yourself, why has it taken 6 years? Well here's a little background.
I currently live in a mobile home, on my property (acreage) located in the country, which is "Paid in Full". When my wife and I decided to build, it was with the understanding that we would NOT get a new mortgage and risk the property that is now owned by us. We also knew there was only way we could afford our dream house, and that was to pay cash each step of the way, and build it ourselves. So trying to save money, and doing MOST of the work ourselves, is why it has taken so long.
Now, about that Spray Foam.
This is one of the very few projects that I eventually hired out. However, I do regret to say that I tried using the Soythane DIY kits, but it was a disaster. This is not meant to discredit Soythane. It just didn't work for me (but that's another story). I was actually able to get the house sprayed by a pro for less money than what the kits cost. But hey, I tried.
I know there are lots of folks, who discredit foam and think there are better alternatives (etc., etc.). And there are a lot of folks who believe in foam such as me. PLEASE, this is not meant to be a debate on whether foam is bad or good. I'm only trying to share MY experience. If this information can help someone who is contemplating whether or not to use foam, that would be wonderful.
Before I proceed further, let me first say many, many, thanks goes to energy_rater_la for all the valuable information that she has freely given on this forum. We corresponded back and forth by email a couple of times (a few years ago) and I very much appreciate the advice I received.
House Details:
Location is near Baton Rouge, La.
Daily High Temperature is currently about 95 deg. F. with high humidity
5,700 Sq. Ft. (3,840 on 1st floor, 1,860 on 2nd floor)
ROOF Construction: 8" average open cell foam, 1/2" plywood decking, moisture barrier, Galvalume metal roofing.
WALL Construction: 2"x6" Studs with 5" open cell foam, 1/2" drywall, 1/2" plywood, house wrap, 1" foam sheathing (reduces heat transfer through the studs), 1/8" air barrier, Hardi Plank siding.
Concrete Slab
More than average Large Double Pane Vinyl Windows
Full Sun, 2 feet overhang
Very air tight construction
Keep in mind that I do not live in the house yet so I do not have a stove in use. But I have kids and we do have a lot of traffic in and out.
Now the COOLING results: UNBELIEVABLY Good.
The 1st floor is maintaining a temperature of 68 degrees and the 2nd floor is maintaining about 73 degrees. BUT WAIT. I haven't told you the BEST part yet.
This 5,700 Sq. Ft. house is being cooled by only one (1) small 8,000 BTU window unit!!!! When friends come over to visit they are in shock.
Now to be fair, I must say that the window unit can only maintain that temperature. If I were to shut the unit off for several days and allowed the house to warm up, I doubt the window unit would be able to bring the temp back down. It can only maintain.
The A/C calculations for this house is only 3 1/2 Tons. I hope to have the Central Unit installed by the end of this summer. I will probably have two -2 ton units.
Now here are the results for this past winter:
I think the coldest days we had here were about 27 degrees. The house NEVER got below 60 degrees.
I rarely turned on the heat, but can you guess what I used?
It was a 1,500 watt ceramic heater. Again, it would not raise the temperature in the house, but it would maintain what it already was. Even when it was 27 degrees outside, it was a comfortable (to me anyway) 60 degrees inside.
The a/c unit in my trailer broke a couple of years ago and I'm currently using 4 window units in the small 16 x 80 trailer and it isn't nearly as cool as it is in the large house with only 1 unit.
Sorry for the long post, but I'm so excited about my results that I had to share.
jennybc
Epiarch Designs
Bull Run Architects & Building Designers · Morganton Architects & Building Designers · Pedley Architects & Building Designers · Gardere Design-Build Firms · Alhambra General Contractors · Bel Air General Contractors · Clarksville General Contractors · Country Club Hills General Contractors · Deer Park General Contractors · Fort Lee General Contractors · Gary General Contractors · Henderson General Contractors · Modesto General Contractors · North Tustin General Contractors · Port Saint Lucie General Contractorscarsonheim
Brian_Knight
susan133476
galore2112
