| My home is a typical 2-story with attached garage. One of my (2nd floor) bedrooms is extremely hot due to having the longest duct run. The room has one wall, part of which is shared with the garage attic. The attic and the remainder of the wall exposed to mid to late day sun.
I would like to add insulation board to the garage attic wall. Can I just affix the board to the existing studs? My concerns are about fire hazards and condensation issues (inside wall/craft paper backed FG insulation/insulation board). As an aside, both my main and garage attics have full (open) soffit vents, front and back, as well as ridge vents. I have NEVER been able to demonstrate any airflow in either attic. They are extremely hot. Any insulation experts on board? Thanks. V
- Posted by energy_rater_la (My Page) on Fri, Jun 29, 12 at 22:31
| so the upstairs wall of this bedroom faces into the attic? this is acessable from the garage? use a 1" xps foam/foil sheating board to cover if you can continue the foam board to the sheetrock of we do this quite often at change of ceiling if you can stop the air movement then the do you have baffles in the rafter bays best of luck. |
- Posted by veesubotee (My Page) on Sat, Jun 30, 12 at 7:23
| Thank you for your very thoughtful response. I was concerned of possible code violations. Responses to your questions and some follow up follows: "So the upstairs wall of this bedroom faces into the Actually, the attic is accessible from a first floor ceiling hatch. "use a 1" xps foam/foil sheating board to cover Not familiar with 'button cap' nails. Can you elaborate? Aren't there foam boards that interlock precluding the need for foil tape? "do you have baffles in the rafter bays to keep insulation out of soffits? are soffits free and clear so that air Yes, there are baffles and they are all open (light enters). Likewise, the ridge vents are open. Original ridge vents were made of perforated metal, but were replaced with Cobra type vent. Neither metal nor Cobra vent allowed any air passage. The soffitts are perforated aluminum. I once started to calculate the actual free air space, but got way-laid. I take it that I need not be concerned about the foil faced board trapping moisture between it and the sheetrock. Winter time indoor humidity usually runs about 40% max. Thanks again for your help. V |
- Posted by energy_rater_la (My Page) on Sat, Jun 30, 12 at 19:10
| http://www.acehardwareoutlet.com/ProductDetails.aspx?SKU=998009895 interlocked foam board like dow blue board best of luck. |
