Installing Slate Tile over a living space. ( Exterior Deck )
johnfrwhipple
13 years ago
Featured Answer
Sort by:Oldest
Comments (7)
johnfrwhipple
13 years agoRelated Professionals
De Pere Architects & Building Designers · Forest Hill Home Builders · Frisco Home Builders · Garland Home Builders · North Ridgeville Home Builders · Prichard Home Builders · Reedley Home Builders · West Jordan Home Builders · Chicago Ridge General Contractors · Clive General Contractors · Columbus General Contractors · Parsons General Contractors · Riverdale General Contractors · Troutdale General Contractors · Vincennes General Contractorsjohnfrwhipple
13 years agojohnfrwhipple
13 years agoBy Any Design Ltd.
8 years agolast modified: 8 years agoBy Any Design Ltd.
MATERIALSThe Most Popular Roofing Material is Affordable and Easy to Install
Asphalt shingles, the most widely used roof material in the U.S. are reliable and efficient, and may be right for you
Full StoryKITCHEN BACKSPLASHESHow to Install a Tile Backsplash
If you've got a steady hand, a few easy-to-find supplies and patience, you can install a tile backsplash in a kitchen or bathroom
Full StoryEARTH DAYHow to Install a Green Roof
Covering a roof with low-maintenance plants has benefits beyond just beauty. Get the details here
Full StoryPATIOSSpring Patio Fix-Ups: Install an Outdoor Fireplace or Fire Pit
Make your yard the place to be by adding a fire feature that draws a crowd
Full StoryREMODELING GUIDESInspiring Materials: Slate Tile
Texture, Color and Strength Makes Slate a Go-To Material for Inside and Out
Full StoryFENCES AND GATESHow to Install a Wood Fence
Gain privacy and separate areas with one of the most economical fencing choices: stained, painted or untreated wood
Full StoryEXTERIORSRoofing Materials: Slate Makes for Fireproof Roofs That Last
It stands up to weather and fire without losing its high-end look. But can your budget handle it?
Full StoryREMODELING GUIDESFinishing Touches: Pro Tricks for Installing Fixtures in Your Tile
Cracked tile, broken drill bits and sloppy-looking fixture installations? Not when you follow these pro tips
Full StoryMOST POPULAR13 Upgrades to Make Over Your Outdoor Grill Area
Kick back on your patio or deck with a grill that focuses on fun as much as function
Full StoryDOORS5 Questions to Ask Before Installing a Barn Door
Find out whether that barn door you love is the right solution for your space
Full StoryMore Discussions
bdpeck-charlotte
