How much to install tile on diagonal?
mcfromct
KITCHEN BACKSPLASHESHow to Install a Tile Backsplash
If you've got a steady hand, a few easy-to-find supplies and patience, you can install a tile backsplash in a kitchen or bathroom
Full StoryFLOORSWhat's the Right Wood Floor Installation for You?
Straight, diagonal, chevron, parquet and more. See which floor design is best for your space
Full StoryREMODELING GUIDESContractor Tips: How to Install Tile
Before you pick up a single tile, pull from these tips for expert results
Full StoryBATHROOM DESIGNHow to Install a Toilet in an Hour
Putting a new commode in a bathroom or powder room yourself saves plumber fees, and it's less scary than you might expect
Full StoryMATERIALSThe Most Popular Roofing Material is Affordable and Easy to Install
Asphalt shingles, the most widely used roof material in the U.S. are reliable and efficient, and may be right for you
Full StoryBATHROOM DESIGNShould You Install a Urinal at Home?
Wall-mounted pit stops are handy in more than just man caves — and they can look better than you might think
Full StoryFENCES AND GATESHow to Install a Wood Fence
Gain privacy and separate areas with one of the most economical fencing choices: stained, painted or untreated wood
Full StoryREMODELING GUIDESDIY: How to Install a Door
Homeowners who aren't afraid of nail guns can tackle their own pre-hung door project in a couple of hours
Full StoryPATIOSSpring Patio Fix-Ups: Install an Outdoor Fireplace or Fire Pit
Make your yard the place to be by adding a fire feature that draws a crowd
Full StoryBATHROOM DESIGNHow to Match Tile Heights for a Perfect Installation
Irregular tile heights can mar the look of your bathroom. Here's how to counter the differences
Full StoryMore Discussions
mcfromctOriginal Author
lazy_gardens
Providence Architects & Building Designers · Aliso Viejo Home Builders · Immokalee Home Builders · Lewisville Home Builders · Four Corners General Contractors · Catonsville General Contractors · DeRidder General Contractors · Dorchester Center General Contractors · Foothill Ranch General Contractors · Lewisburg General Contractors · Muskogee General Contractors · Nampa General Contractors · North Tustin General Contractors · Renton General Contractors · South Windsor General ContractorsmcfromctOriginal Author
LuAnn_in_PA
GreenDesigns
brickeyee
renovator8
worthy
