| What percentage of a home construction budget should be put into the cost of windows & exterior doors (not including the entry door and garage)?
What are your thoughts on a budget for a home that costs $450k to build (not including land)? |
| there is really no answer to this question. They can be anything, it just depends on the design, brand, etc. A 450k house could have very few windows or walls of glass. About the only thing you can do is meet with your designer/architect and work out the elevations. Select your window brand options and get pricing. Just a single window can vary hundreds apart due to brand. |
- Posted by mydreamhome (My Page) on Tue, May 29, 12 at 9:55
| "Just a single window can very hundreds apart due to brand." ...and size, shape, function (DH, SH, Casement, Fixed), grid design & structure, window structure (vinyl, aluminum, aluminum clad, vinyl clad), glass options (single pane, double pane, triple pane, Low-E, tint, argon filled, etc). If you're trying to duplicate an historic look, windows can run big $$$$$. If you're looking for basic windows, then significantly less $. |
| If you are just looking for 'typical' there are numerous insurance underwriting guides that are used to estimate replacement costs. It is not a good way to plan if you want anything more than 'average.' |
- Posted by EngineerChic (My Page) on Tue, May 29, 12 at 20:02
| Also, is that $450k including site prep like clearing trees, putting in a full basement, and septic field? I was going to say that windows in our second floor addition were about $7k out of $105k, but that doesn't mean you should plan to spend $28k of your windows. |
| $470k including prep but not including appliances, landscaping, gas install, etc. Our window options have been ALL OVER THE PLACE! Needless to say it can be frustrating to have to decide. At the lowest end base would include lumberyard quality vinyl windows at a cost of $8k (approx 20 standard to large windows and 20 small windows in the 3-4 sq ft range. These are included in the price. Mid option would be thermally broken aluminum windows Our highest option would cost us $20k more (including two exterior doors and set of french doors in same color PVC). These are Mahogany finished high end Polish PVC windows.
| In your part of the country, is $470K considered a high end build or a mid-range build? I don't know of any area of the country where the median new-home price is well above $470K so I'm pretty sure you're not building a low-end house. Windows are not something that you should "cheap out" on. Thus, I definitely would not use lumberyard (builder's) quality vinyl windows in any home that cost more to build than whatever the median new home price in my part of the country was. Our window/door package (not including installation costs and not including front door or garage doors) ran nearly 15% of our total budget but I think 7% to 10% is generally considered about average. |
| I'm curious to hear where you end up with this as our cost to build is fairly similar, though, we haven't gotten to budgeting specific items yet. As for the cost to build being around $470k, that is well below the average home price in my area! |
- Posted by david_cary (My Page) on Sat, Jun 2, 12 at 6:13
| 15% bevangel? That is very high IMO. We spent about 3% and 4% on the last 2 houses. The 4% was for vinyl but it is an oceanfront house and that included impact glass. The 3% was for wood which was hard to get away from with our HOA and our color scheme. Both houses are much more window heavy than an average new house. The oceanfront house has a wall of windows 14 ft by 7 ft. Even 10% would be $47k which is very premium windows and very hard to justify. |
- Posted by EngineerChic (My Page) on Sat, Jun 2, 12 at 9:25
| Hi BAVE, Thanks for answering what the $470k included. Regarding window options, we went with Marvin Ultimates (aluminum clad exterior, wood, SDL, double hung). Whatever you choose, make sure you SEE the windows in a showroom before you buy them. I chose Marvin's partially because of the way the outside looked when you are really close to them - we will use them on the first floor (when we replace those windows) and we have a front porch, so any options with weird looking weld joints on the outside just weren't options in the end. Good luck with your choice, it's a big decision so don't feel rushed. |
- Posted by Renovator8 (My Page) on Sat, Jun 2, 12 at 9:31
| % prices can be used for very rough cost estimating but they should never be used as a design guide. Window design is one of the most subjective and personal parts of a house. |
- Posted by palimpsest (My Page) on Sat, Jun 2, 12 at 11:52
| I had estimates for a single window (although the low was a four-lite, and the high was a spoked circle in a square) The low was $1000 and the high was $8000. (historical) This isn't typical pricing because I could've gotten a basic vinyl for about $100+, but the point is there was a factor of 8X. I didn't do the window, I left the opening parged in. |
| For our home I'm definitely not going with cheap $6k windows though here in Texas most would. On the higher end, mahogany colored PVC European windows will cost us $26,000 (+tax# but this includes larger windows as well as two matching exterior doors and a set of matching French doors. The actual windows will be $22k. The difficulty for us is matching a window style to the home. White PVC will not look good while aluminum may look a bit cheap compared to the European PVC windows but would only cost approx $14k #not including doors# for Don Young thermally broken. The PVC windows #Polish: http://www.drutex.pl/en/products/windows/pvc-windows/iglo-5.html) actually look like wood and add to the Santa Barbara style fo the home. The builder has shown us these on a few 10k sq ft plus homes in our area. I've attached a drawing of the home. |
Here is a link that might be useful: Front of Home
| I gotta say. That's not what I was envisioning for $450K. |
| A $600-700k home (land/home) in Texas gets you quite a bit of bang for the buck. Cheap labor but poor resale values in most areas. |
- Posted by athensmomof3 (My Page) on Sat, Jun 2, 12 at 20:36
| I think windows are a very important part of the build. They can make or break a house, aesthetically. Plus they are a permanent deal and not easily upgraded. Our windows were between 3 and 4 percent of our build but a much more expensive build. We have a few casements (more expensive) and did a fairly expensive window (Kolbe and Kolbe Ultra). We also had about 40k of french doors (wow those suckers are expensive and we had way too many of them!). |
| BAVE - That sounds like a good price for the European windows. Are they triple paned? What is the R value? |
| They are double paned but I am not sure what the R value is on the IGLO5 Classic. There are a total of 44 windows (half are normal to large in size) and half are small tower windows, bath, etc. The quote included matching 8 ft tall x 6 ft wide French doors and a pair of matching doors for master and study. This upgrade over lumber yard vinyl (smaller windows as well) and aluminum doors will cost me $20k so we are thinking it is a worthy upgrade. |
| Here are a few images of the PVC IGLO5 demonstrating the wood look: http://i.st-firmy.net/9333ykl/okna-pcv-i-drewniane-pphualexbudsc-grazy na-i-aleksander-rejdak.jpg http://www.weste.pl/foto/35.jpg http://www.erbesp.pl/uploadfiles/thumb/259/800/photo.jpg |
| Bave, those are sharp looking windows! I'm book marking them for when when we get that far along in the process! Though, this whole discussion has me thinking... I like the look of white vinyl windows inside, is that now just generally considered not fancy enough? |
| "Bave, those are sharp looking windows! I'm book marking them for when when we get that far along in the process! Though, this whole discussion has me thinking... I like the look of white vinyl windows inside, is that now just generally considered not fancy enough?" We have white vinyl int/ext in my current Florida Mediterranean style home and it looks great with this style. We just do not think it will look appropriate with the look of the new home. Here's the IGLO5 in white: |
| I quite like both! I'd like the wood look on the outside, and white interiors.... I'm getting ahead of myself first, I need to finalize a floor plan first! :) |
- Posted by EngineerChic (My Page) on Sun, Jun 3, 12 at 6:39
| The wood look is nice. It has the appearance of butt joints instead of miter joints, which is what led me to go with aluminum clad windows (the welds on miter jointed vinyl windows were not attractive to me). I only looked at one of the links you posted, but it showed interior grilles. Are they available with SDL? That is an upgrade that is worth the cost, IMHO, esp if you have any large windows. Also, there is a GW forum devoted to just windows as a topic, too. They might have experience with this manufacturer to offer. |
| Yes SDLs are available in various styles. We'll go with SDL at the front (large windows) and at the family room exit to the patio. The rear of the house has large windows viewing the pool area and will not have SDLs. |
| We have nut wood colored German vinyl windows. One of the upgrades we went with is black rather than silver colored between the glass spacers. We felt the black blended better with the dark colored vinyl. This picture you posted shows the silver spacers. I can't seem to locate a close up picture of our windows where you could see the black spacers. |
| How long have you had the windows? Have you had any issues with them and would you recommend them? Thanks. |
| We moved in on 1 Apr, so we have only been in the house for 2 months. Ours are Hoco brand and we would definitely recommend them. We have their H150 profile with triple panes. They have a number of different profiles. Here is the profile we have but, of course, ours look much different because they are not white. |
| Those look nearly identical to the Drutex Iglo5 windows. Who is your US supplier of them? The Hoco sites don't point to any US distribution. Are you concerned about future replacement availability for parts, etc. considering they are not US made? |
| Eurostar Fenestration. Our salesman was Armin Reischl in Charlotte NC. No, we aren't concerned about future replacement. We figure Hoco has been around for a long time. |
Here is a link that might be useful: Eurostar Fenestration
- Posted by millworkman (millwork4u@gmail.com) on Mon, Jun 4, 12 at 8:10
| It has long been a fact the quite a few European Co. are further ahead in fenestration advances than the US. The major downside is making certain you choose a company that has solid distribution in the US and that the company is stable and will be around for the long haul. That and the logistics of getting the product in a timely fashion to the jobsite. |
| Sorry I'm just getting back to respond to David Cary's questioning our spending about 15% of our budget on windows and doors. Yes, I agree that 15% is a very HIGH percentage but we have an unusually large number of windows and doors. I like lots of natural light and like to be able to walk outside easily so every major room in my house gets light from two sides and has a patio door or two leading directly outside to a porch or deck. Fifteen (yes 15!) exterior doors and forty-four windows add up. As I said, I think 7% to 10% is probably much more the norm. |
| Looks like we'd be at around 6-7% of build cost if we go with the European windows & doors. Going cheap would put windows & doors at less than 2% on windows and doors, which is equivalent to what we spent on additional dirt. |
| Hi BAVE, My name is Armin, and I am the co-owner of Eurostar Fenstration, we are the national distributor for Hoco, Stabil and Bayerwald windows. |
| Thanks GWMAN. I already placed an order for windows from Poland. We went with an order of 45 windows and three sets of doors all in Mahogany finished/colored PVC. |
| I don't know why my post is showing up three times??? |
| Hi BAVE, I understand and I hope everything is going well with your window order. |
- Posted by millworkman (millwork4u@gmail.com) on Fri, Jun 15, 12 at 8:56
| gwman, that is great info as I have sold UPVC Foil Mahogany windows out of Canada and I was trying to remember the two types of foil and the exact differences and uses of each. I will have to store that away in my memory bank for the future. |
| millworkman, we can order both foil from our venders in Germany and Austria, I always explain the difference to my customer, so they can decide which foil they want to use for their windows (the acrylic foil cost about 12% more than the PVC foil). Also the supplier for the acrylic foil gives a 10 year warranty for his foil in the US. Most PVC foils if they are from Europe have only 5 year or no warranty, if they are sold in the US. |
