Mon, May 21, 12 at 6:58
| To eliminate grout/simplify maintenance & provide a cleaner look, we've been considering solid surface options to finish interiors of showers in our new build. We don't like the look of cultured stone or molded surrounds. It seems that quartz solid surface could work well (for example Caesarstone). But mostly they're available in only 20mm thickness (cpl mfrs offer thinner tiles and limited thinner slabs).
I'm wondering if using this material is appropriate? Seems the slabs will be hard to secure from movement, and I haven't seen it done elsewhere--which leads me to believe that there must be overwhelming reasons against. Appreciate feedback. Is trying to use quartz solid surface a bad idea? Are there other solid surface materials to consider? Many thanks, Mark |
| I had a custom shower pan made out of Alantra. It is awesome. It was expensive, but it's is solid, no grout lines, and easy to clean. My walls are tiled. This is solid surface not a cultured product. Plus, I was supporting my local economy. |
Here is a link that might be useful: Solid surface product
- Posted by glenwood705 (My Page) on Thu, May 24, 12 at 20:25
| i have a friend that did two bathrooms showers in corian. shower pans were corian and three walls. the look was great and super easy to clean. |
