heat mat placement question
illinigirl
9 years ago
GREAT HOME PROJECTSHow to Add a Radiant Heat System
Enjoy comfy, consistent temperatures and maybe even energy savings with hydronic heating and cooling
Full StoryFLOORSWhat to Ask When Considering Heated Floors
These questions can help you decide if radiant floor heating is right for you — and what your options are
Full StoryFLOORSIs Radiant Heating or Cooling Right for You?
Questions to ask before you go for one of these temperature systems in your floors or walls (yes, walls)
Full StoryLIGHTING5 Questions to Ask for the Best Room Lighting
Get your overhead, task and accent lighting right for decorative beauty, less eyestrain and a focus exactly where you want
Full StoryGREEN BUILDINGConsidering Concrete Floors? 3 Green-Minded Questions to Ask
Learn what’s in your concrete and about sustainability to make a healthy choice for your home and the earth
Full StoryEXTERIORSCurb Appeal Feeling a Little Off? Some Questions to Consider
Color, scale, proportion, trim ... 14 things to think about if your exterior is bugging you
Full StoryGREEN DECORATING8 Questions to Help You See Through Green Hype
With the ecofriendly bandwagon picking up some dubious passengers, here's how to tell truly green products and services from the imposters
Full StoryBATHROOM DESIGNWarm Up Your Bathroom With Heated Floors
If your bathroom floor is leaving you cold, try warming up to an electric heating system
Full StoryFLOORSFloors Warm Up to Radiant Heat
Toasty toes and money saved are just two benefits of radiant heat under your concrete, wood or tile floors
Full StoryGREEN BUILDINGInsulation Basics: Heat, R-Value and the Building Envelope
Learn how heat moves through a home and the materials that can stop it, to make sure your insulation is as effective as you think
Full StoryMore Discussions
rrah
nepool
Holtsville Architects & Building Designers · Portage Architects & Building Designers · The Crossings General Contractors · De Luz General Contractors · Dothan General Contractors · Greenville General Contractors · Groton General Contractors · Leominster General Contractors · Medford General Contractors · New Bern General Contractors · New Milford General Contractors · Norwell General Contractors · Rohnert Park General Contractors · Vincennes General Contractors · Wyomissing General ContractorsillinigirlOriginal Author
nepool
_sophiewheeler
kirkhall
Jack Kennedy
debrak2008
Annie Deighnaugh
bus_driver
shifrbv
musicgal
debrak2008
kirkhall
renovator8
debrak2008
musicgal
debrak2008
musicgal
