| Hi. I know this is a really simple front door, but I can't seem to find one like it.
I am looking for a 3'X7' door with side lights and a transom - should be 8' total. It must meet impact requirements for FL code. |
| It reminds me of the front and side doors that we put in this house. Ours is painted, but you could get get it unfinished and stain it. If I remember right, I had a hard time finding this door as well. Finally found it at Kolbe & Kolbe. |
| Thanks for the information. I will check it out. |
| It might help you to know that the door you pictured is sometimes referred to as a "half-lite" door (because the glass section takes up approximately half of the door) but is also sometimes called a 9-lite door because the glass is divided into 9 sections by grills. Unfortunately, "9-lite door" is also sometimes used to describe doors with a Prairie-lite pattern regardless of whether the glass is half-lite, 3/4 lite, 2/3rd lite, or full lite. The sidelites you show are usually called 3-lite sidelites but are sometimes also just called half-lite sidelites. Confusing isn't it? Which of course makes internet searching really difficult! I did find a place where you can get the door and sidelites you pictured in solid wood but they don't seem to sell transoms. The link is below. Whoever is supplying your windows might be able to supply you with a 5 lite-transom window to go above the doors. Good luck.
Here is a link that might be useful: door and sidelites
| Brosco has a door like this in their catalog. The one in the link is pine; they have it in other woods, too. Brosco can be ordered from HD and other suppliers. |
Here is a link that might be useful: Brosco 9-light door -- bottom left row
| bevangel & Chibimimi - Thanks so much for the information and suggestions. I will definitely look them up. I have also found that I can get a similar look in Pella & Andersen with impact so that will be my fallback. Thanks! |
- Posted by kamkar2006 (My Page) on Sun, Apr 1, 12 at 16:38
| Therma tru or jeld wen? |
| Thanks Kamkar2006 - I did not find what I was looking for with thermatru or jeldwyn, but they did have similar doors. |
