vapor barrier under concrete floor?
Posted by OntarioMom (My Page) on
Wed, Mar 21, 12 at 19:00
Hi all,
We are getting ready to pour the concrete floor in our basement, and then we will do the garage floor. We have decided to do 2 inch rigid insulation under the cement in the basement floor and are wondering if we should also do a vapor barrier?
In terms of the garage floor, we are laying down the 2 inch rigid insulation around the perimeter of the garage floor, with just the gravel in the centre of the garage. The insulation is rather costly and the garage will not be heated (hence only putting it in the perimeter). However, we also wondered if we need a vapor barrier under the garage floor?
I am getting conflicting info on the necessity of a vapor barrier so I would appreciate hearing what others who live in a heat dominated climate have done under their garage and basement concrete floors. BTW, I live in southern Ontario so it is not that cold (sort of like a Niagara Falls NY).
Thanks,
Carol
RE: vapor barrier under concrete floor?
Two-inches of XPS is classified as vapor semi-impermeable, so no further barriers are needed. A vapour barrier under the slab is optional in a typical garage. But if you're storing collectible vehicles, it would be a good idea, as it slows vapour inflow into the garage.
(I build in the GTA.)
Thanks Worthy for your help. I didn't know the XPS was classified as semi-impermeable. We are not storing collectable cars in the garage, just regular cars, bikes and other storage. We have very sandy soil. I'm guessing poly plastic under the slab would keep the stored goods dryer. What did you put under your garage floor?
Carol
See here, first link, p.7.
Actually, I've never used any vapour barrier under garage floors.
For these and a few other questions you've posted, there would have best been recommendations in your building specs from a local P.Eng.* who reviewed the plan. However, I know many/most designers here don't go that extra step. Considering even the cost of a modest home, I think the $500-$600 cost would have been worth it.
*mrs. worthy's OBY/GYN is also a P. Eng., but we've never solicited construction information from him!
Hi Worthy,
I will check out the link you posted -- thanks! The architect did consult with a structural engineer several times (and we paid more than $600.00 for this service). Not sure if the engineer was involved in doing specs for the garage floor, but I doubt it. I agree having a P.Eng review plans is important. I start second guessing when the contractors offer different opinions than what the architect has in his specs.
Carol
They try this on me all the time too, sometimes in as a belittling way as possible. ("Have you ever built a house before?") More often than not, it involves them saving money and effort rather than improving the durability and longevity of the building.
