Driveway - concrete or asphalt
andry
Featured Answer
Sort by:Oldest
Comments (10)
rrah
10 years agoDreamingoftheUP
Palmer Architects & Building Designers · Troutdale Architects & Building Designers · Riverdale Design-Build Firms · Ammon Home Builders · Alhambra General Contractors · Arlington General Contractors · Avon Lake General Contractors · Country Walk General Contractors · Linton Hall General Contractors · Port Huron General Contractors · Springfield General Contractors · Summit General Contractors · Waimalu General Contractors · Williamstown General Contractors · Austintown General Contractorsallison0704
10 years agobus_driver
10 years agoRNmomof2 zone 5
10 years agoandry
10 years agonicole__
10 years agomdln
10 years agoautumn.4
CURB APPEALHow to Reseal Your Asphalt Driveway
Protect your driveway and keep it looking great by applying new sealer every couple of years. Get the details here
Full StoryREMODELING GUIDESConcrete Driveways: Poring Over the Pros and Cons
Concrete adds smooth polish to driveways and a sleek look to home exteriors, but here are the points to ponder before you re-surface
Full StoryMATERIALSPrecast Concrete Pavers Make a Versatile Surface in the Garden
You can use concrete pavers in a variety of shapes and colors for your patio, walkway, driveway and more
Full StoryPATIOSLandscape Paving 101: Cast-in-Place Concrete
A construction standard, cast-in-place concrete can be used for a wide variety of project types
Full StoryREMODELING GUIDESGravel Driveways: Crunching the Pros and Cons
If you want to play rough with your driveway, put away the pavers and choose the rocky road
Full StoryCONCRETEWhy Concrete Wants to Crack
We look at the reasons concrete has a tendency to crack — and what you can do to help control it
Full StoryEARTH DAYHow to Build a Greener Driveway
Install a permeable driveway to keep pollutants out of water sources and groundwater levels balanced
Full StoryLANDSCAPE DESIGNGarden Walls: Pour On the Style With Concrete
There's no end to what you — make that your contractor — can create using this strong and low-maintenance material
Full StoryGREAT HOME PROJECTSHow to Give Your Driveway and Front Walk More Curb Appeal
Prevent injuries and tire damage while making a great first impression by replacing or repairing front paths
Full StoryGARDENING AND LANDSCAPINGRenovation Detail: The Ribbon Driveway
Grass paired with concrete for the driveway is more than just pleasing to the eye — it's good for the environment and your home
Full StoryMore Discussions
dgruzew
