Mon, Mar 26, 12 at 1:43
| I've found a small triangle shaped lot that I want to buy. However, I need to determine what size house would fit.
The left side of the triangle is 36.86. The right side 52.8. The bottom of the triangle (front of house) is 75.79. I don't want a triangle shaped house. What would be the maximum width and depth I could build not taking into count the setbacks? |
- Posted by sombreuil_mongrel (My Page) on Mon, Mar 26, 12 at 8:00
| The size of the lot is 887.359 If that is square feet (you did not specify any unit of measure) it is clearly not a buildable lot. Casey |
| If the dimensions you provided are the construction lines: 405 square feet (27' wide x 15' deep +/-)if you want a perfect rectangle. 520 square feet if you want a litle bit of a shape (combining two rectangles). Is this for a one car garage, casita or an tiny cottage? |
- Posted by finallyhome (My Page) on Mon, Mar 26, 12 at 14:29
| Well, I was hoping to be able to put a small 2 level home above a 2 car garage. This is an infill lot in an urban area close to downtown. I only want a small 1300 - 1400 sq ft house so I am limited in the available lots. I don't want a condo or a one of the larger townhomes in the area. Most older houses in the area are being torn down for new builds. But since the lots are going for $150K to $200K, it doesn't make financial sense to put such a small house on these lots, nevermind the fact i'm never cutting grass again. I was hoping this lot would work. |
