Cost of concrete slab for patio?
Posted by azdreamhome (My Page) on
Wed, Feb 8, 06 at 13:23
Does anyone know what the cost of a concrete slab (to be used for tiling a covered patio) would run (by square foot)? I searched the archives and couldn't find anything on this (plus it keeps going up anyway).
What is the going rate per SF? Or do they quote it another way?
RE: Cost of concrete slab for patio?
Have no idea in AZ, but here, south central IN. Depending on the mix it is $85-$95 dollars a yard depending on psi strength, hot water, calcium, fiber, etc. One yard will get you 80sq. ft. at four inches thick. Add 10% for grade variations, you dont want to run out. We have a $50 fuel surcharge for any load under four yards. Finishers around here charge $.50 per sq ft. just to finish. To form and finish around $.80 per sq. ft. I know our two ready mix plants went up seven dollars a yard on 12/1/05. Hope it helps...
bwallen149 -- thanks for the quick response. So using your numbers (it's a bit confusing for me to figure out), how much would an 1,100 square foot patio come to? Again, this will be the foundation for a tiled patio under cover. Thanks for your help!
Ours was probably a little high since it was done by the builder but was $3/sq ft.
Is this to form and finish, finish only, and how thick do you want it... I am going to guess at 4", that is what almost all slabs, garage floors, driveways, sidewalks, etc. are poured around here. The concrete at 4" would be about 15.2yds. Roughly $90/yard so roughly 1375 in just concrete. $.50/sqft to finish so about $550. If it needs formed and finished figure about $.80/sqft. so $880. Youmay also have the cost of a sealer, 5gals should cover it, less than $60. And some guys charge to come back and saw "crack joints" in it. I would think less than $75. One other question, you said this patio is covered. Is the concrete going to support some kind of roof system. If so you need to think about some sort of footer for any edge that has a load on it.
Our driveway installer just quoted us $4000 for 1200 square feet, 4" thick, rebar reinforcement, exposed aggregate. That's about $3.33 s.f. We're in Seattle where labor costs are high.
$5 sq. ft. by my builder in Atlanta. If you don't want to get stuck with a small 23' side entry garage apron width you have no choice but to use the builder and pay his surcharge. Win some, lose some.
Thanks everyone! We will be tiling the concrete foundation we pour. I'm not actually sure about how many inches the foundation needs to be (but at least 4"). I wanted to get a rough estimate here before I spoke to my builder about it so I had some knowledge on the subject. You have been very helpful. bwallen149 -- you have been extremely thorough and it really helps!
Our concrete was $2.60 per sf.(mat & labor) We are in NW Ohio. That included 4" thickness and either a smooth or broomsweep finish. Good Luck!
I live in Houston TX I am a concrete contractor. I charge $2.40 a sq ft for 4 inch thick patios with 3/8" rebar on 12" centers. My concrete cost $73 a cubic yd and 3/8" rebar runs $2.30 for a 20 ft length. My cost includes all grading forming and to pour and finish the concrete. If you are pouring against your house slab you need to have an expansion joint seperating the two slabs or you need to dowel the two slabs together. Before you seal your slab check with the tile installer. Good luck with your new patio.
Az dream. I live in Az and paid less than $3 sq ft less than a year ago. This was for a side walk, patio extention and pad for hot tub. About 1000 sq ft. Formed, finished etc for about $2500, and this when concrete was hard to get. Good Luck !
Most builders will charge you $4.50 or more, ours wanted to.
in NJ. I was just quoted $2500 for 4" thick, 420 sq ft. dyed concrete. This included grading. Seems high by what you all are saying....
It's funny that this thread popped up again today (thanks sprengle1). They poured our back patio, courtyard and some other stoops just a couple hours ago! We are paying a little less than $3/sf and it is supposed to be about five inches thick (we will be putting tile on it). Here's a photo of our "wet" back patio:
"Wet" concrete back patio looking west:
"Wet" concrete back patio looking southwest:
concrete over an existing patio
I live in Houston and want to have a new concrete patio poured. The plan is lay slate tile over the new patio. There is an existing patio which was pour in 1995, however, it slopes toward the house and causes water to puddle near the slab. Can I pour over the existing patio? In order to level the area I will need about 5 inches next to the house and 2 inches 15 feet from the house (25 feet in length). Please tell me that I don't have to remove the existing slab!
azdreamhome could you please forward me the name of your
concrete contractor?
I am in AZ central phoenix starting a garage addition and starting to get quotes.
Thanks Gspeed
Hi Bob 681 from Houston. I am planning to put a concrete patio on my backyard. Would you like to send me your contact numbers? I will give you the details of the job and address.
Thanks
I live in Magnolia (FM 1488 & FM 2978) which is a suburb of Houston, Texas and am interested in adding on to my 10' x 10' concrete slab patio on the back of my house. I want to make the patio 16' deep and run the entire length of the back of the house (about 41 ft). If any conctractors want to bid on this, then please email me and include your company name, website (if you have one), phone number, etc? I was thinking about make the outer edge (41 ft outer edge of the patio) have a curve to it rather than making the patio a boxy rectangular shape. I will eventually cover the patio (probably match the roof shingles on the house) so I want to add a thicker outer perimeter for the patio to support the load, but the rest will be 4 inches thick (should be sufficient). One more thing that might affect pricing...the concrete truck can be driven through my side yard to the back of my house, rather than wheelbarrowing the cement to the back. Let me know if you are interested and provide a price. Right now it is just weeds and wild grass. Please indicate if your price includes removing vegetation, digging/leveling/grading, building forms, pouring concrete, finish, etc.
Thanks,
Brian
brmatthews:
We are owner-building in Magnolia. I justed wanted to give you the info of the guy we are using for our slab. After talking to 5 companies, we chose him. He's out of Conroe - Percy Cassard (Cassard Concrete Constr.) 936-539-5101 office 936-537-1999 cell.
RE: Cost of concrete slab?
I have been looking for quotes for a concrete slab to extend my existing patio. Roughly 200 sq ft at 4" with a 4" gravel base. I am getting prices closer to $10. I was expecting about half that. Have costs gone higher this year?
$10/sf?
Here in the DFW metroplex, I see lawn signs at houses with newly poured concrete driveways advertising 4" concrete slabs for $3/sf.
I'll have to subscribe to the win some / loose some philosophy. I payed $6/sf to my builder. South Carolina.
Hi,
Someone else mentioned the possibility of pouring over old concrete. I've got a situation with a patio in pretty bad shape - uneven and once apparently covered with a glued on outdoor carpeting. There are wood strips between the squares which aren't in great shape. There's a very unsafe concrete slope from near the door sill down to the patio. I had been thinking about redoing the whole patio, but would it be possible to build up the patio about 2-4" on top of the old so it comes to the same height as the top of the little concrete ramp there now (and then have another ramp as required further on out away from the house). Would be nice to be able to do a pour-over but don't know how wise this would be.
Anne
Paid $3.25 per sq foot for my driveway and small smoker pad, turnkey. The concrete is 4" thick with rebar - not mesh, and with brushed finish and curved sidewalk.
Bob681 or tegemen email bobs contact info to me please dreamscapestx@yahoo.com
No one has mentioned removing grass. Pricing seems to be on cleared land without grass. How much more is your contractor charging for cutting out ummmm lets say 2000 square feet @ 4" (40x50)of established st augustine sod for a new basketball court. Is $5bucks/square ft too much especially since steel/rebar and fuel costs have gone up? were in the Houston burbs south of i-10
AZdreamhouse,
Sorry to jump in, but what kind of columns do you have? Are they concrete or cast stone? Where did you get them??
Thank you!
Bob681 ... Please send me your contact info to ... rm2tea@aol.com. I live in Houston and need some concrete work done at my house and possibly a few others. Thanks.
I live in San Diego, CA., and seeking quotes (local contractors) on a 10 x 20 patio concrete slab. If interested, please email me at bensan@san.rr.com. Appreciate your time, Sincerely, Bensan
Here in Oklahoma we got a quote of $3 sq/ft. Seems pretty average as far as the replies here.
2008 prices in Maryland for 4' concrete (3,000 psi):
4' unreinforced $3.50 per square foot
4' with fiber reinforcing $3.65 per square foot
4' with wire reinforcing $3.75 per square foot
4' with rebar reinforcing $4.25 per square foot
4' stone base add $0.50 per square foot
4' stone, colored, stamped, sealed $12.50 per square foot
Call (301)663-0626 for a quote
Here is a link that might be useful: MK Concrete
Bob681 and any other concrete/foudation specialists, please contact me at sambeanies@yahoo.com . I need a driveway and foundation poured.
I need a 1200 sq.ft 4" thick, smooth finish slab poured does 3.00 per.ft cover concrete, sod removel and compacted rock base?? what would be a resonable price to pay for this project?? Good luck AZ
Hi Bob 681 from Houston. I am planning to put a concrete patio on my backyard, 17x20 "340 square feet" Please send me your contact info, I am looking to get this done within a week or so.
Thanks
Jonathan
Jonathan,
Did you got Bob contact info? I also want to make a 10x32 concrete patio. almost like yours, a bit smaller - 320Sq ft
what quotes are you getting?
Thanks, AM.
ps.: my email is moraes.andre@gmail.com
Anyone know of any good concrete companies in dallas area? i put up my own forms, backfil, and rebar. All i need is them to come out and actually pour. 21 ft out from the house and 32 feet long
I'm a contractor from San Antonio Texas and we just did a 2000 sq.ft slab with a rebar and 4" tick at 2.00 sq.ft for a patio and we will be puting Flagstone on it next week.
manuelm:
I am looking for a contractor to extend my driveway (wider) and add an entrance patio to the side of my garage. I am located just north of San Antonio TX. Please send your business contact information if you are interested
I live in Fallbrook CA. Most companies want 4$-5$ per foot.
I hired the guys that the contractors hire and supervised it myself for $1.87 per sq. foot.
$2366.00 28.5 yds concrete
$ 350.00 wire mesh
#1490.00 Labor total.
I am extremely pleased with the entire job. I cannot find 1 flaw anywhere.
I have pictures but cannot figure out how to post them.
I am in the Cypress area of Houston and looking to add-on the the existing patio. The additional size to be 8x10x4"thk. What would it cost to do this. If you do this for a living, contact me and give me your best price.
RE: Need concrete slab for patio
I am in the Cypress area of Houston and looking to add-on to the existing patio. The additional size to be 8x21x4"thk. What would it cost to do this? If you do this for a living, contact me and give me your best price.
I'm from South of Houston: Richwood. I do concrete work. Our price on concrete is a bit higher; it just went to $120 a yard, with a $100 short load fee under 4yards. Rebar is about $3.50-4.00 a stick. Forms are about $.93 Lin ft.
Residential
12'oc #3 4' slab formed and finished at $5.00 sq ft- all day long til concrete goes up again for small jobs.
1000 sq ft and more; price is less.
Commercial and industrial may be significantly higher for many reasons.
Here is a link that might be useful: Nation Restoration Corporation
Looking to build a 324 sq ft room and 45 sq ft bathroom onto our house. Looking for concrete/slab contractors. I am in the Conroe, Texas area. If you are a contractor, please e-mail me at tdlucas1959@att.net Looking for bids. Thank you!
In Tucson, AZ - looking for someone to pour a 16' X 8' X 4" slab of concrete in the backyard to extend the existing back patio to the full length of the house. Please send an email with a complete quote to include prepping the area, finishing, sealing, crack joints, etc.
I live in Grand Rapids, MI. I'm looking into a concrete slab for the first step of what will eventually be a screened porch. The size is yet to be determined. I may also want a circular pad poured in the center of the back yard for the dining table and chairs. It would probably be cheaper to have them do them both at the same time.
Does anyone know what concrete is costing here per sq ft in Michigan now? Poured and finished--with a rebar reinforcement? Also, will they charge more to make a round patio for me rather than just a box shape?
Hi Bob681 from Houston, Can you please send me you contact info? I need a concrete patio on my back yard done. my email is mikeannac@yahoo.com. Thank you,
First, I am amazed this thread is 5 years old, but I wanted to thank everyone for their input. I'm a pretty good do-it-yourself person when it comes to remodeling, but for big pours of cement, I leave that to the contractors. In northeast Kansas, Dan Hooyer of Hooyer Concrete 785-562-3603 is meticulous and does fabulous work. I've seen walls, floors, and color. When I did my own patio, I had sloping issues and the finish wasn't evenly smooth. When Dan did the garage floor and walls...perfection.
As far as cost, I should have paid to have Dan do my patio. I may have saved on the labor, but it's like comparing Picasso (Dan) to a grade school fingerpainter (me). A valuable lesson in cement.
I am a concrete contractor in Houston, TX. (www.conspecinc.com) After reading these treads I am amazed at how little people really know about concrete placement. First, the smaller the job = the more it costs because we are charged a "short load fee" for orders under 6 yards. This fee can be up to $175 "plus" the cost of the concrete. Also - for slab on grade applications wire mesh is much better than rebar (contrary to popular opinion). It has to do with the fact that reinforcement on "slab on grade" applications is based upon the strength of the GRADE not necessarily the reinforcement. The reinforcement just prevents the crack from developing and wire mesh does a better job. I address this on my website. Finally, concrete costs have gone up as the economy (gas prices), drive costs. I charge $6 to $7 PSF for stamped colored concrete and $3.50 to $4 for standard. In Houston, contractors have a habit of putting wood for control joints which ultimately rots out. Not a good idea. I don't use wood for control joints unless requested. Also concrete can be ordered in MANY WAYS! A contractor can order substandard concrete (but the owner does not know the difference), cheap.... but GOOD concrete costs about $80 per yard. In short a concrete patio "should" cost $3.50 to $4 PSF in Houston that is - if you seek quality. Concrete can have "fillers" which after 28 days "will" give you 3000 PSI but "after" this period it will slowly diminish. Good concrete however, increases its strength with age. Good concrete takes 50 years to totally cure. My website gives you the truth about concrete placement.
Thinking about replacing my wooden patio for a concrete one, live in league city tx, looking for an estimation, it will be 16 x 30 - email: only1me@gmail.com
We are trying to have a driveway extension approx 12x24 ft with base to level site to 4" approx coupled with a patio 15 x 15 ft x 2 inches thick. Rebar, foundation forms and labor running $3k and concrete truck approx 13 yards @ $1.5k...in Spring Branch Texas...Does anyone think this is an outrageous cost? One contractor submitted a $7k bid. Thanks for any responses. Oh, PS, we are hill country grade, drought in 110 degree weather? Still sound reasonable?
Response to Limtg - Patio/Drive cost
I would be VERY careful in placing concrete two inches think on your patio. The ONLY way this should be accomplished is if you make SURE the sub-grade is compacted to a minimum 1500 PSI. The strength of "slab on grade" concrete is vested in the SUBGRADE - not necessarily the concrete. Most do not understand the simple fact that the slab of concrete is only as strong as the "grade" or what the concrete is placed on. It does not matter how much steel, rebar, or reinforcement placed into it - if the subgrade is faulty you will have a problem futuristically. I am a concrete contractor (28 years experience and degreed), and try to explain the MANY misconceptions about concrete placement.
For example - people call it "cement" which is like calling flour a cake. Cement is only one of the basic "INGREDIENTS" in concrete. Think of cement as the glue that bonds everything else together. The more cement one puts in the mix = the stronger the concrete. People erroneously believe reinforcement makes concrete stronger, but in reality the amount of cement in the mix determines the strength. For more information and the truth about concrete go to my website at www.conspecinc.com.
Hi, thank you to everyone who has been posting.
I am looking to get a quote for a 12X12 concrete slab. I am south of Houston Tx (Texas City) and looking to have this done in the next week or so.
Email: flyat37k@ymail.com
Cost of concrete sidewalk & patio?
Sidewalk: $5 - $6 per square foot. Over 300 square-feet the price will decrease as size increases.
Patio: $6 - $7 per square foot. Over 500 square-feet the price will decrease as size increases.
Stamped & colored: $9 - $14 per square foot.
Costs increased in 2010, 2011 and for 2012 with increase in fuel & materials. Concrete is backbreaking labor to build framing, move materials and correctly finish concrete.
Are the costs, to consumer, estimates posted on January 18, 2012 still accurate?
I'm going to need a contractor to install some 30' of walkway & a 12'x16' patio.
I live in the Spring, TX area off of FM2920
I'd like to hear from interested contractors.
I live in Houston Metro area and like to have a driveway extension approx 15x35 ft before Feb. 2013. Please email me pwang0611@yahoo.com for more information.
Thank you.
