TJI vs Steel beam
houses14
9 years ago
DESIGN DICTIONARYOpen Web Steel Joist
Give your roof or floor a support network, woven between the beams
Full StoryDESIGN DICTIONARYBeam
This horizontal piece of wood or steel gives support to a home's architecture
Full StoryDESIGN DICTIONARYSteel Girder
This framing element is strong enough to support floors, roofs, catwalks and more in a single bound
Full StoryARCHITECTUREDesign Workshop: Getting a Feel for Steel
Versatile and strong beyond belief, steel can create amazing expressions in homes and landscapes
Full StoryREMODELING GUIDESFraming Design: Structural Expression in Steel
Exposed Steel Framework Defines Modern Living Spaces, Inside and Out
Full StoryMATERIALSSteel Connections Make Strong Impression
Steel joints provide more than just industrial-strength architectural support; they add a mighty dose of character
Full StoryWINDOWSSteel-Framed Windows Leap Forward Into Modern Designs
With a mild-mannered profile but super strength, steel-framed windows are champions of design freedom
Full StoryMOST POPULARHouzz Tour: Elbow Grease and Steel Create a Modern Texas Farmhouse
Talk about DIY. This couple acted as architect, interior designer and general contractor to build a one-of-a-kind home on a budget
Full StoryLIVING ROOMSRoom of the Day: A Steel-and-Wood Bridge Spans a Great Room
An architect helps a San Francisco couple create an open living space that combines modern details with a reclaimed-wood catwalk focal point
Full StoryREMODELING GUIDESKnow Your House: Post and Beam Construction Basics
Learn about this simple, direct and elegant type of wood home construction that allows for generous personal expression
Full StorySponsored
More Discussions
amberm145_gw
houses14Original Author
Hockessin Architects & Building Designers · Holtsville Architects & Building Designers · Boise Design-Build Firms · Bellview Home Builders · Home Gardens Home Builders · West Pensacola Home Builders · Winchester Center Home Builders · Kearns Home Builders · Coatesville General Contractors · Fort Pierce General Contractors · Gallatin General Contractors · Greensburg General Contractors · Mentor General Contractors · Sulphur General Contractors · Walnut Park General ContractorsUser
jdubb
