Wed, Dec 28, 11 at 14:52
| is it problematic or annoying to only have one function for the rain shower head? Also, faucet direct confirmed you can use the jets, handshower and rain shower at once if you have enough water pressure. We'll have well water, might this be a problem? thanks for any comments! |
| Well water , city water, rain water, doesn't matter. It only matters how much pressure your delivery system can deliver with regard to this set up. You can buy a pressure gauge for around 10 bucks and see what yours is. Pressure is not the ONLY issue. You'll need to be able to flow/send/deliver enough hot water to use two features in that setup. Figure 5 gallons a minute for as long as you want to use it. |
