| My BR is 10' x 6'8". Tub will stay at the far end of the room along the short wall. This short wall is an exterior wall. One of the long walls is an exterior wall too. |
- Posted by lazygardens (My Page) on Thu, Nov 10, 11 at 22:06
| Your picture is not showing up |
- Posted by bill_vincent (billvincent@hotmail.com) on Fri, Nov 11, 11 at 7:26
| Your floor will be stiff enough, but you still need to add a layer of plywood over the planking before anything else. Being that you already have the beef in the planking, you only need 3/8" ply (exterior grade). On top of that, you can put your heating system, and bury the wires in self leveling compound (make sure you use the bonding agent the manufacturer makes for this condition), and then go over that with Ditra, and you're then ready to tile. Figure 3/8" ply, 1/4" heating system and SLC, 1/8" Ditra, and 3/8" tile= 1 1/8". As for the joisting, what's the size of those joists, the on center spacing, and the span? |
| Thanks Bill V. Very helpful. The spacing of the joist is 21" OC. The length of the joist are about 10', free span, but possibly 12' total taking into account the ends that sit on the plate. I had meant to ask on my post if there would be a tile size limitation such as 12x12 or 16x16. I was thinking of doing a small Versailles pattern where the largest is probably around 16x16. As I mentioned, this part of the house is joisted differently than the rest of the house, I think they where saving some lumber;) My DIA (dear inlaw ancestors) had this bathroom addition put on over the crawl space after they moved this small house from town and onto the farm. The rest of the house is sitting over a regular basement. My late DFIL and his sister hand dug the basement when they were teens. They used the horse team and a slip. DH remembers his dad talking about how hard the soil was. His DD said when the slip hit the hard soil and bucked, he'd end up on the backs of the horses. He must have been standing on the slip. |
- Posted by bill_vincent (billvincent@hotmail.com) on Fri, Nov 11, 11 at 15:37
| They look to be 2x8's in the picture. If that's the case, then yes, you want to add another joist in between each of them. As for size limitation, you add those joists and build the subfloor as I described above, and your floor will be rock solid enough to use whatever size tile you like. |
| Yes, these are 2x8s so I will talk to DH about adding joist. Thanks so much Bill V, you are always so helpful and courteous:) |
