JOIN NOW LOG IN
Height of handheld shower?
Posted by andreadeg (My Page) on
Thu, Nov 19, 09 at 15:52
Hello,
I need to decide soon (probably by the end of the day!) how high on the wall I would like to have my handheld shower placed. We bought the Kohler Bancroft line of faucets and the handheld shower will not be on a bar, but instead, will be placed on a hook. The internal shower dimensions will be 3.5 feet by 4.5 feet. The longer side of the shower will have the shower head, on off valves, built in shelf etc. I'm thinking of putting the handheld shower on the 3.5 foot wall which is opposite the door. (The shower will be curbless if that is an important detail). How high up on the shower wall would you recommend we place the handheld shower? I'm 5'0" and my husband is 6'0". We will have the option of having the water flow from the shower, the handheld shower, or both.
Thoughts and opinions appreciated!
RE: Height of handheld shower?
Since you will have a stationary shower head mounted on the wall, you could mount the hand held shower at a lower position.
Do you ever take a shower and not want to get your hair wet? If so, then mount the head at your shoulder height so can do this. I think this is also a good height so you can easily grab the shower head to rinse down the walls and floor after you do a cleaning.
Why not get one on a bar so it's adjustable?
We didn't care for the look of a bar in the shower.
We're are doing a handheld showerhead in addition to the showerhead as well. Our shower is 36" x 66". We are mounting both on the short, end wall, with the handheld between the showerhead and the long back wall. I bought a 6ft long handheld so I can clean the shower easier, so it will come out of the wall even with the controls, drop down and loop back up again higher to the holder position. We also did not want the adjustable bar. I haven't quite decided exactly where I'm going to put the holder, but I think I would like it high enough to where I can take a shower under it if I wanted (I'm 5'4") and also grab it to clean the shower. Since it's 6ft long, I probably have to mount it a little higher so wont drag on the shower floor.
Since you are under-tall like me as well, mounting it lower may be good for you to access for cleaning the shower.
Thank you both for your recommendatios. I think I'll for for a 4 feet 6 inch heigh which will allow me to clean the shower floor, and, take a shower without getting my hair wet! Thanks again!
