| The vanity we are using is 39X21 with the sink being 40" wide. Is there a rule as to the size of the mirror to use over the vanity?
I want to put sconces on each side of the mirror so I need to start looking for the proper mirror so the electrician can determine where the electrical boxes should be. Argh.... |
| Yeah, make it big enough so you can see yourself clearly.... I sorta like the mirror to be the same width as the sink, but obviously if the sink is up against one wall, or both walls, you'll need a narrower mirror to fit the sconces in (especially for surface-mounted cabinet mirrors that protrude from the wall), unless they are built into the mirror. Be sure the mirror is several inches taller than anyone who is going to use it or else you won't be able to see the top of your head. |
| My mirror size choices are either: 31 1/2 X 37 3/4 OR Sconces on each side of the mirror. The mirror is just that not a medicine cabinet. |
| Thanks lee. How high would the mirror have to be hung? The vanity will be floated at 36" and the mirror I think I have to use (to accomodate the sconces) is the 31 1/2. If I rest the mirror at the top of the vanity it will only be 67" from the floor. Is that a little too low? |
| It depends on how tall the tallest person is that is going to use that bathroom. My husband is 6.2 and 67" would be too low for him. Is your mirror framed, or unframed..also, what is your ceiling height?? |
| I think it is probably too low not that I have any idea how tall the tallest person would be to use it. It's a bathroom basement. unframed and the ceiling height is approx 7 1/2 ft. I think we need a 4" backsplash. |
| If you are using the 31.5 x 37.75" mirror and you hang it vertically...then you are at 73.75..not 67. If you use a 4" backsplash than you bring the mirror up that much higher. That would be fine... |
| You are absolutely right. Do I need the backsplash then? |
| Ugh then the standard height for the sconces of 66" would be too low if I do the back splash. Right? Wrong? Get me a tape measure.... |
| I think the height of the sconce is somewhat dependent on the length of the sconce and personal preference. Robern has a 10.2" sconce that I was looking at and they recommend that the junction box center be 2" above center line of the mirror. HTH... |
| 2' about the center line? Really need that tape measure don't I? I was looking at the Eurofase Donna but have read some reviews that don't make me happy. We wanted to mount them vertically. So I went searching more and found this Alico fixture. http://www.lightinguniverse.com/bathroom-lighting/alico-industries-bv8 61-10-15-enterprise-bathroom-light-chrome_g262419.html?isku=2277976&li nkloc=cataLogProductItemsImage
Here is a link that might be useful: Eurofase
| Check out houzz.com for some ideas... |
| I have a linen cabinet and vanity being custom made, and need to decide what size of mirror to put there. The linen cabinet is 14" (and tall), vanity is 40" right next to linen cabinet. The rectangular sink (17") is not centered on the vanity, it will be more to the right which means I can't put a mirror in the center of the vanity, it won't look good. So, I can order 40" mirror that covers all open space above vanity or put standard mirror right above sink. But I'm not sure having mirror that is not centered will look that good. Any suggestions? ****** ****** ****** ****** ****** ****** ************************************ ***********************000000000**** ***********************000000000**** ***********************000000000**** ************************************ ************************************ |
